Cleat stress question
Capt. Art
In moving to a new winter slip, I need to allow another 47 ft boat to tie just a bow line for the winter to my forward most cleat. I'm blocking his access for the bow dock cleat & I must take this specific position to fit. I'm Port Side & Stern In against a floating dock. On the Starboard Side there is a short 30 ft finger seperating my boat & his. I'm 60ft he's 47ft. He can make fast his whole Starboard & Stern to his side 30'floating dock. He just can't get a line from the bow to the dock on his Port Side. My idea is to make my Bow Cleat a double line, double tie to the dock & then continue a line from my Bow Cleat to His. I'm trying to equalize the stress & expecting the total stress on my bow to the dock at twice the normal weight stress so I'm using double lines of 1 inch that should be more then enough? I'm thinking I've equalized the bow cleat stress and just adding it to the dock side cleats? Any flaw in my thinking? And, would you guys allow it?
Sounds viable Art. Have you seen pics of the marinas when they buckle down for a hurricane? I've seen pics of similar setups where they use snubbers or even inflated tire tubes. I think there has to be minimal stress between the two boats unless you're actually trying to hold him off the dock. If you don't think snubbers would work maybe poly line will give that lil' bit of stretch before it tries to yank your cleats out of the deck. *shudder*
I would select a line size that would part before my cleat pulled out
you do what you must. try to keep the lead parallel to the cleat not perpendicular. consider using a forward spring cleat as well if you have one. three strand has more stretch than braid for less shock load.
The big snubbers can really reduce shock stress. I'd put them on the lines on both sides of your bow. A line from his boat across your bow to the dock may work to greatly reduce stress on your cleats if you can do it so your boat and his line are adequately protected from chafe.
it's hard to visualize the set up from a description... from what i understand, since he is shorter he can't tie up on his port side and must tie up to your boat.
that's fine as long as you spread the loads. can you have two lines from the dock to your boat, ideally on two different cleats on your port side ? and then one line from your stbd side to your nieghbor's ?
snubbers are a good idea, along with triple strand for stretch
a kellett is also a great snubber, adding about 10x its weight to resist the line stretching tight.
I would consider a line from his bow to yours and another line from his bow to one of your midship cleats. If I read you correctly there is a finger between you and your neighbor's boat so even if you use a midship cleat at 30 feet it should clear the finger.
" I'm Port Side & Stern In against a floating dock. On the Starboard Side there is a short 30 ft finger seperating my boat & his. I'm 60ft he's 47ft. "
I had a similar set up with my boats at floating docks during the storms a few years back. I always tied them together bow and stern and they did better than many of the boats at our marina.
As they've said in earlier posts-spread the load as much as possible. Your conditions may not be extreme enough to be an issue but during Wilma I had two deck cleats break and one dock cleat break with this set up. Luckily I had enough back ups to avoid damage.
