Coffee on the hook
jodon2
Can anyone recomend a decent 12 v coffee maker while on the hook? Heard there are some that take 45 minutes to brew. Too long for me. Thanks
I've tried just about everything and the best solution I've found was a single burner kenyon stove, and a stainless perkulator from cabella's...real coffee...
Don't waste your money on a 12 V coffee maker. I've tried a few and they all suk. Last one we got, was expensive from a trucker supply store, took 45 mins or better to brew a small 4 cup pot. Now it's a glorified strainer. We heat the water on the alcohol stove and just pour it into the basket of the coffee maker. On the upside if you do it this way it'll keep your second cup warm while it waits in the pot. Other than that it sucked up more than the advertised 10 Amps DC and kept tripping the 20 Amp breaker. The only way I could get it to work at all was wire it directly to the house batteries with 6 Ga wire on a run less than 8'.
as much as i hate to admit it, on the hook i drink instant. it really is not to bad, just a little after taste however considering i am anchored out i am ok with that.
i just use my microwave to heat the water.
I need my coffee, and I like the good stuff. We grind with an inverter, boil water over the alcohol stove (or magma) and then pour over the filter basket sitting on top of the pot.
The grinder is from home and the brewing process is the same as the Bunn we use - so I don't have to compromise. Quick, easy and the coffee is hot - plus you can give it a light warming over the burner if it needs it. This year I may take the insulated pot and try that.
tcijoe...I am so sorry to hear about your instant coffee. Some things are just worth cranking the generator on for!!
"i just use my microwave to heat the water"
why not just turn on the coffee pot!
If you truly want a great cup of coffee and have a burner this is the way to go. It is the Santos Stove Top Vacuum Coffee Maker by Bodum.
http://www.bodumusa.com/shop/line.asp?MD=1&GID=3&LID=542&HID=1208-01&groupline=
0&barker=1&CHK=&SLT=&mscssid=LH0JQMS1DVHW8GM9C6GF5DHH6QRKDRR1
I use the electric version of this at home and it makes a great cup of coffee and is cool to watch. As the water is heated in the bottom the pressure forces it up the tube, through the filter into the top section where the grounds are. It brews up there for a few minutes then when you remove the heat source (the electric shuts off on it's own) the pressure drops and the coffee drains back down very quickly into the bottom carafe again.
I haven't used the stovetop one but I imagine the coffee is just as good if not better.
My buddies bought me a Kurig for the boat - but it requires 120v. If you can boil water, you can make a GREAT cup of coffee using a French Press....
We simply use the 110V pot. Fill the filter as usual. Boil the water on the stove then pour it into the filter. End result is the same as the pot doing the heating.
I boil water on the alcohol stove, toss the coffee into the pot and strain it through a coffee sock
after a few minutes.
A smaller pot of hot milk and I have very good, strong coffee
seriously i just do not want to store a coffee pot on the boat. it is just me that drinks it.
the instant is really not that bad.
generally speaking my genny runs from the time i leave the dock until the time i return.
Originally posted by The Other Gary
I second the Kenyon stove and percolator.
This is what I do, too. Although next time I think I'll try pouring the boiling water into my 110 Mr Coffee and see how I like that.
When I was a teenager, my Mom had a vacuum coffee pot for the stove top. It made great coffee until it got broken. I sure would not want that Santos onboard! Too fragile.
A good cup of coffee on the hook is the only way to start the day!
Get an inverter and use a coffee maker. You will use the inverter for many other things. I use a 1500 watt and works fine. It runs my fridge when I am under way and then I can switch it back to normal power when genset is running or shore power. I wired it to an outlet so I can plug anthing into it I wany to use,TV,coffee pot,cell phone,etc. No need to run generator just to make a pot of coffee. You can always just run the engine while the coffee pot is running to charge the batteries.
I've had good results from three different methods:
1) Boil water w/ gas burner, add coldwater coffee extract
2) Boil water, use Melita filter directly into a thermos.
3) Inverter and a standard 110 Mr Cofee
If you already have a stove then the percolator is the least expensive ($20) way to go. Otherwise install an inverter and use a regular coffeemaker.
I used to have to set up breakfasts for teachers meetings I used to cater (picky bunch). I am not a morning person and tried to get anything and everything done the night before. I decided to try brewing coffee the night before. After some experimentation, it worked. I would brew the coffee and transfer to zojirishu brand thermal caraffes around 6-8 at night. The next morning, the coffee was still piping hot and exceptional tasting even to 8 am!
The coffee does not cook like it would in a pot with a heating element.
Be warned, no other caraffe will work except zojirishu brand from what I found. They are the ones who developed/perfected the thermal caraffe manufacturing process. The SS/Chrome pot with the screw top vacuum top is the best. I order them direct through the company I work for but I have seen them on some websites. Look at target.com and search for "Zojirushi Easy-Serve Handy Pot". That is the best one I have found.
Hope this adds another alternative for you!
Six minutes.
