Started work on the new master a couple of week ago. First opened th wall between the guest room and the back of the master closet, then moved the closet in the old guest room. Will build a vanity on the other side where teh drawers are piled up in the pictures.
Also gutted both old heads and removed the wall between the heads and the companionway.  Final step to date last night was getting the tub in. Head is so big that we decided to put in a whirlpool tub instead of a shower.
The space partially visible behind the tub will be a pump closet where I am moving teh air con pump (and adding a back up), both AC and DC fresh water pump as well as, eventually a watermaker.
Updated timeline right now is to finish the master by the end of the month, at least the bulk of it, then in December start working a number of mechanical things I need to do before the engines are swapped like batteries, Chargers, fuel tank cleaning, new racors, etc...tryin to plan haul out in January for engine swap, new shafts, replace all thru hulls, etc..
Updated pics of the master in the FB album linked above
