compression issues
naylor427
i have a yamaha l250 txrr 6cyl two stroke engine in my posession with no compression in cyl #5 .however when i plug the spark plug hole wilt my finger i get suction and pressure .... am i looking at a reed valve issue?
or do you think there are more issues at hand>..
Your finger is sensitive to a couple pounds pressure. Even with a major leak, like a hole in the piston, you can get a "couple pounds".
Definitely not reeeds, unless one broke and went into that cylinder. That would have scored things up pretty well. Rings totally gone or a hole in the piston. Look through the plug hole and bring the piston to the top. You'll probably see something wrong on the surface. If you don't, teardown time.
