Just to add some additional points. I wanted to stay away from cored hulls (bottom AND sides) until I ended up owning an older Slickcraft (Tiara). It was not cored on the bottom, but it was cored on the hull sides just above the waterline. To this day, it was the best built boat I have ever owned. The way they cored the sides, the coring was IN ADDITION TO, an already substantial fiberglass layup that could have stood on its own. The final hull side thickness was 7/8" and amazingly strong. The coring added strength and a significant amount of damping (both sound and structural) to the hull. It was the most solid ride I have ever seen. It was also engineered and sealed properly. AND....it was well taken care of by owners/boatyards over its life, which was 30 years when I owned it (and still going strong). What I learned was that coring can be done in a way to add a lot of value, and can last a good long time if engineered properly. But....coring can also be done in such a way that the glasswork would not stand on its own without the coring. The coring is a way to build boats with LESS glass and resin, achieving a designed in amount of strength while also saving weight and more importantly cost. Saving weight is a double edged sword. In some fashion, it can allow a boatbuilder to equip the boat with smaller engines, but still achieve good power/weight ratio's and save the cost of a larger engine footprint. Depending upon the boat, that can be a good thing, but can also produce boats that are so lightweight for their size that sacrifices are seen in both stability as well as the surefooted ability to shoulder their way through a larger sea. In MY opinion of what makes for a good boat, these are the wrong reasons to use coring. "Beancounter" engineering at its worst. Now, I stop short of saying that designing strong panels at a minimum of weight to be a bad thing. In most cases, its a good thing. Especially if you are designing a panel to support a flybridge, where you want a certain amount of design strength at an absolute least amount of weight up high. Coring is a great way to do that.
Anyhow, the short of it is this.
1.) I still would never own a boat cored below the waterline, just too risky.
2.) But...I've grown to not only accept but sometimes prefer a boat cored on the hull sides above the waterline.
3.) I've learned that while cored panels have inherently more risk than non cored panels, done correctly they can easily last the life of the boat, while adding superior value.
4.) Finally, but not least of all, the REASON WHY the manufacturer cored a certain component is of utmost importance. Even if the panel never fails, coring to blindly save weight and cost is not always a good tradeoff, but as of late a strong trend in the industry.
...just my $.02
