As some of you may have read, after a few tribulations I sold the boat back in May. I got an email the other day from the new owner saying the block was cracked so now I have some questions.
Let me give you a little background first. The boat was pulled last September and I had the marina change the oil, which happened around early October. The boat then sat in heated indoor storage until I pulled it out at the end of April. The marina dropped the boat in the well, and I took a quick 15 minute spin to make sure everything was working before I loaded it on the trailer. It was then towed to my house where it sat a few weeks until it sold.
The buyer made the sale contingent upon a compression test, a vacuum test, and a sea trial, which the boat all passed. The buyer has said he has only used the boat 3 times when he found the block cracked. It did not crack at the cylinder wall, but is letting cooling water into the oil from what I can gather. My questions are ...
1) The boat was only run 4 times since an oil change and that oil change found no evidence of water, Now, the oil has turned to "milk" per the new owner, is this possible.
2) I didn't do much to winterize the boat except the oil change, stabalize the fuel, and pull the batteries as the marina had touted the benefits of heated storage included not having to winterize the boat. Were they right.
3) The compression test was done by his local marina. Is it possible for them to not notice the cracked block while performing the test.
4) The bill of sale says "As Is". I think I'm covered but the buyer sent me pictures showing rust around where the block had cracked, implying it was a previous condition. If it was a previous condition, which I doubt and even if it had cracked I had absolutely no knowledge of it, does he have any recourse.
Thanks in advance for your answers.
