if you look at the angles of the lines to the boat, you'll see right away why the boat / stern wont' move sideways as much when the lines are crossed.
If it is unpractical to cross the line (boarding, dinghy, etc...), depending on your slip you can sometimes put your sternlines to cleats or pilings off to the side and get the same effect.
I can hardly think of a time where tying an inboard stern line is appropriate, yet that is what most people do 90% of the time. It's just bad seamanship. What you are reacting to, is having seen it done wrong so many times that when you see it done right, you think its wrong.
"I can hardly think of a time where tying an inboard stern line is appropriate"
??? You rarely/never tie the stern?
Perhaps you meant, ( never ) tie it straight to the nearest point, vs crossing the line to the opposite side cleat ( correct ).
There are several reasons why, and they become obvious the first time you see a boat "hung". The point of tieing a boat to the dock is to keep it there, without damage and without constant maintenance of the lines. This is best accomplished by having -all- lines make long runs, vs short runs.
( Ghost: Ok, I got ya. You mean tie not to the inboard side as in near the dock, but to tie to the outboard side, the side farthest from the dock. vs, the way I read it, meaning ... on a boat with an inboard engine... ) The likely reason why I misinterpreted what you said was that I envisioned a boat in a slip, rather than "along side" a dock. Hmmm, even that is a poor description. I give up. Ghost, yes, I agree with you.
G, he means do not tie the line from the dock to the closest cleat ( inboard to the dock ) but tie the line to the far side cleat, the one farthest from the dock ( the outboard cleat ). Took me a couple of minutes to get it, as well.( ie: he's got it right, but for some, like me, it is not immediately obvious. )
In a floating dock, when I stern in, I do not want the lines across my swim platform as I use it to board the boat. I tie the dreaded short runs, but I have no tide or current to worry about as Lake Erie doesn't fluctuate that much.
side to, I usually set up the stern line on the dockside cleat (inboard), while docking. once the engines are off, I replace it with a stern line going to the off side.
less chances of the stern line falling in the drink and getting in a prop... it's also easier and quicker to pass ashore and fasten if i'm alone than having to get it on the other side.
