Crossing Stern Lines?
fountain27
I relocated my dingy to the swim platform and now crossing the stern lines is difficult. How bad is it just to run the lines straight?
it depends on your slip. Crossing your stern lines helps stop the side to side movement of the boat so if your slip is fairly wide it's not a big problem. If your slip is too narrow and the uncrossed lines dont' prevent the boat from banging into pilings then it could be a problem.
I cant' cross my lines either but i'm able to get them from the outside from cleats on the the edge of the slip. that's enough to keep the boat centered.
If you are going to use your neighbor's cleat to achieve that, ask him before though.
If you have a tidal change and you're not at a floating dock make sure your lines are long enough to compensate for the tides if you're not going to cross them.
Thanks for the advice. Our tidal surge is not bad.
Got to love BE for response < 15 mintues.
Pascal, I am addicted to your web cam. Can you upgrade to streaming? :)
We have the same issue but fortunately are tied to floating docks. In addition to running the two stern lines up, you may have to add a spring line. We have springs on both sides of the boat they help keep the boat centerd in the slip as well as keeping it from moving too far back.
