Cruise Alone ?
Looking at catalog now for HH VHF and EPIRB.
George, looking at go around to Rudee as their is more to do there than Lynhaven. I have only seen that water from the beach or the bridge. How is it?
Oh yes, water activated stobe and whistle too. Maybe better vest with attachment points for all equipment I will have on my vest when I leave the bridge (after I stop the boat :)) I plan on built in GPS EPRIB. Seems beter than PLB and SPOT.
about the submersible VHF... i usually add short safety strap with a clip to make sure it doens't slip up the belt when you do the wrong movement. Some clips are plastic and can break off it you bang against something.
I cruise out into the Gulf of Mexico alone sometimes in a 34 foot Mainship. Usually within 40 miles. The solitude is pretty relaxing but sometimes singlehand operation can get tiring. Just keep the work day reasonably short and you'll do fine.
Just a quick note about planning.
Even if you have automation onboard (Nav, GPS, Autopilot); Before you start your run each day, make a "running journal". In the journal, you should have a running list of the times, course changes, bouys/markers expected, etc.
eg:
11:30am - buoy 23, turn to 310Mag, distance to next mark XXX. LAT: xxxxx LON: xxxxx
11:45am - etc, etc,
Singlehanded, you'll want to reduce your workload as much as possible. Get the navigation out of the way beforehand, and concentrate on piloting the boat.
+1 on the other comments about fatigue and keeping your workday reasonable.
Rudde's Inlet is fairly narrow, keep it as sraight and in the center of the channel as possible. Watch the waves going in. Don't slow down slower then the waves until you are passed the beach or you run the risk that the waves turn you around. Do not get flustered by all the anglers near the bridge. Do not "aim" for their lines but do not try to get into a dicey situation trying to avoid them. It is there job to pull them in. The southern bay is actually quiet boring as you are more likely far away from land. Not much to see. Should be about 3 hours from the mouth of the Potomac. I usually catch the bad weather coming back up the bay. If you have any southernly winds of 10kts+ it will be a long ride back.
Turbo, how old are you? How is your health?
I have crossed the stream back and forth to the Bahamas and fished offshore, some times alone. Now that I am 71 years old but still in very good health, and seeing some of my younger friends have serious health issues, I have decided to use better judgment and not go alone.
Wouldn'T want to arrive at my destination lying on the deck.
"To soon old, To late smart"
Use common sence, have a great,safe trip. I do wish you well.
Most of my boating is single handed, but none is in your area.
Above comments are all valuable. Planning an preparation is important, and careful use of limited resources are essential. The most critical is you. The post about fatigue and the care and maintenance of the human is important. Be sure that at no point you allow yourself to go below "minimums"; that is: at any time the fertilizer could contact the ventilator, and you will need to be capable of dealing with is, alone, without difficulty. Don't push yourself, plan so that you are always well within your skill and endurance levels. Prep everything that can possibly be done beforehand ( including alternates! ) so as to off-load those tasks from the real-time activities.
Simple actions such as: Carry a thermos of prepped coffee, and sandwiches, vs intending to brew coffee at sea or preparing a meal. Keep comfort items at hand, so that you need not leave the helm to dig them out.
It is a different way to operate, and entertaining. It need not be hazardous. Plan ahead and enjoy.
--edit--
I should mention tat the skills honed by single handing the vessel are also very useful when others are aboard. These are valuable skills, and they can enhance all of your boating activities. Do these preparations always and they will not only become second nature, but will mean that you do not need to off-load many tasks to unskilled and unwilling guests! :) Remember that guests are not necessarily crew, and you can have a "full" boat and still be single handing the vessel.
What Big Bliss said. Try to time it for slack tide and avoid wind going one way and tide the other. I have only been into Rudees aboard other people's sport fishers. We had quite a ride once but the captain was an old hand; I have to admit I was little white knuckled myself. Other times were just fine.
This trip, under decent conditions, is not dangerous, per se. It is short and you are in view of land and lots of resources are fairly close at hand. Under indecent conditions, which the Bay is ever capable of, it can range from just plain No Fun to dangerous. Case in point was our trip this fall from Dymer Creek to Hampton Flats. Big following seas pushed against an incoming tide by 15-25kn north westerlies. The trip was ok for us as we could get speed right and have a heavy, stabilized boat. Some sailboats, who, for some odd reason did not have their sails up, were really struggling. Those with sails up were having a fine time. NOBODY was trying to go north that day! However, when it came time to hang a starboard turn into Hampton, I warned the wife to make sure everything was secured. Yeeowks! We made it ok but I was sure thankful to be in my boat. Several others ended up needing help from the CG that evening.
George
Hatteras 56MY
TurboWarp:
You have received some good advice above. You can almost always depend on George for a responsible answer, but you can safely ignore anything he offers on betting the ponies.
I have singlehanded on extended cruises for the last two summers. After a 3000 nm trip over 75 days exploring the Mainland coast of Central and Northern B.C., I was asked this question on the IP forum,
"Since you "single handed" it, any tips for someone considering doing it themselves?"
FWIW, I would offer the same response to you.
"Prepare. You do the boating things together with the Admiral and develop a way of doing things together, like planning the day's journey, weighing anchor, anchoring, docking, taking on fuel and water, preparing meals, doing dishes, daily maintenance and examination of the boat, etc. Before you leave your home port, review all the tasks in detail and turn each one into a process that can be handled safely and efficiently by one person. Two people anchoring the boat, have to cooperate with each other with respect to the timing of their activities in their part of the operation. A single person does it all themselves, and is therefore more aware of everything that is happening, and in no way dependent on the other wrt the timing of the second person's activities. Do this 59 times in 75 days and you might even get pretty good at it! :D
I don't mean to imply that these tasks will be easier to carry out, or boating alone will be more fun, if you leave the Admiral at home, but if you take some time to sort it out beforehand, and apply a logical process to each task, it's all very manageable.
Hope this helps."
Folks,
All excelent feedback. I truly appreciate it, expecially Rudee Inlet. That's probably the biggest unknown for me. Keeping coffee and other personal items at hand on the bridge was something I realy did not think of that much. Indeed, I planned to make coffee at sea. lots of reasons to stay on the bridge. All great ideas.
Thanks everyone, I appreciate and enjoy all the feedback.
Hey Salt, I resemble that remark! But I did win two dollars yesterday at Gulfstream.
Oh, and about that coffee. Keep an empty gallon jug at hand too.
George
Be sure that jug has a screw on cap!
I do alot of single handling. Be sure to practice things like anchoring and docking. First go over the entire routine [process] in your head. Arrange all lines, etc as you will need them to be first. Then try doing the process by yourself. If it doesn't work out as you expected, figure out what was wrong and what to change in the process. Allow yourself lots of time to practice. After you have successfully completed the task several times, you will be able to repeat it during your trip without getting into trouble.
Best of luck; tell your wife you will be fine and promise to contact her every evening to assure her you are not in trouble. I like the fact you are going to file a float plan!!!!
Enjoy.
Joe M raises a valid question and am surprised it wasn't raised earlier. Any health issues that could be a problem if you are solo?
I usually keep some granola bars near the helm and 5 days into the trip north last year, i just had to get an expresso maker up on the FB! thankfully, a BE member (Eric aka Shepdog) came to the rescue and gave us a ride to a store in St Simmons...
when your bladder dictates your range, it's usually time to stop singlehandling :-)
as to health issues, well if you're going to have a heart attack or massive stroke you may not make it... well, if that happens in your car at 70mph on the interstate your odds are no better. so what?
If I have a choice of having a heart attack on the high seas or at my desk, I have my answer.
I carry inflatable jackets, EPIRBs, rescue pods, food and water at all times and will single hand at the drop of a hat. I never go more than a couple hours off shore, anyway, even to the Bahamas.
Everyone, thanks again for all the help and concern. I am in good health. I am in the basement working out right now and am between reps. I better get back to it. I don't want to have a heart attack at all becuase I need to take care of my wife but if I am going to croak I would rather croak in my boat.
Turbo, Go for it. I never listen to my own advice anyways.
Deleted the Croak Poll,Although I was kidding, Thought it may offend someone
