cutlass bearings...
concorde mike
Hi all, Can anyone tell me how to tell if my cutlass bearings need to be replaced? I've looked for a similar thread and can't find one. Thx
any significant shaft movment up down or side to side is too much.
How much is "significant"? I have no movement in one and a click click (hard to describe) movement in the other.
Even tho there is no movement.......uneven wear could indicate misalignment and need for replacement after an alignment. Click, click ??
"Click,click" LOL...lame description of very slight movement. I'm not sure of what you mean by uneven wear Bob, they look even and rubber still pliable from what I can see.
Mike, let's see if I can do this in 1,000 words or less ! If you were to look at bearing from aft end and saw one section thinner than the rest i.e. 12:00, 3:00, 6:00 or 9:00. You then looked at bearing from other end (looking aft). The thinner section w/b opposite the thin end from other direction....WHAT ?? If it was thinner at 3:00, looking forward; it w/b thinner at 9:00. Clear ??
I hope so because I'm getting a headache trying to explain what I mean !!
Uneven wear, being 6:00 on one side and 12:00 on the other side, indicated a shaft out of alignment. General, larger all around wear indicated normal wear. Any ability to "rock" the shaft in any direction means you should replace the bearing. Shafts out of alignment will go through bearing faster too.
That's possible but it's a lot easier to adjust engine/tranny position than to reposition strut.
Whe my prop shaft was un -even in the cutlass bearing, they found the strut was slightly bent and had to be replaced. I don't remember hitting anything hard enough to ben a strut!
FWIW-Often struts can be re-bent to correct.
Thank you all for your input!! Bob, I understood exactly how you explained it. Good news is I don't need to replace bearings.
???? that movment on one side is cause for concern. Do you experience any vibration? Do you hear that click when running??
No vibration, no click, though i doubt I would hear it underway. They look even at all sides and the click is very slight...only thing that concerned me enough to ask the question is that there is NO movement on the starboard shaft.
the starboard is the good one. the other is loose, too loose, hard to tell from here, who knows? You will probably replace it soon and it sounds like a survey for sale would reject it.
As for the comment about bending the strut - that's only available if it's new or newer. I replaced my engine/trans years ago and couldn't lower the engine any more to get the strut aligned. No one would touch it because of it's age. I ended up putting flat stainless washers under the front bolts of the strut. That corrected my angle and I'm on my fourth year with the same bearing. Before that I went through two bearings in two years. I knew I had a problem. I was also told that if I replaced my strut, I could always specify an exact angle too. But the washer method was less pricey.
The yard that replaced the engines on our '88 Phoenix boat in 2003 straightened at least one of the original struts without wedging and indicated it was fairly routine work . Not exactly new or newer but perhaps it depends on composition and certainly on degree of correction needed and certainly condition.
there are many reasons not to use washers the first being that the force is now applied over a much smaller surface area
