cutless bearing
salvatore
what are some of the problems you have when your cutless bearing starts to go besides the grinding noise, does it just go all at once or does it wear and you get no noise or banging. Does it cut down on you speed. Are there other signs of the bearing going bad. I have a 2002 Bayliner with a 5.7 merc and a bravo3.
Good question,
May I add, What is the average life, and how do you check to see if it needs replacing?
Not an expert but one thing is visual inspection. An improper alignment can result in the shaft not being centered in the bearing. I just had mine replaced when I had my tranny issue last month.
They were replaced at my suggestion not the yards but the boat is 5 years old and when I bought it the one engine was significantly out of alignment. Enough so that you could see the bearing compressed in one direction. (Boat had only 33 hours so I opted to just align not replace the bearing but have been watching them) The mechanic told me I had another season or 2 before they would of had to be replaced as they had started to crack. Since I winter in the water and the boat was already hauled I spent the money now instead of later.
Originally posted by walterv
Good question,
You should have no play side to side or up and down (in the strut)...If you have any rattling or movement when you shake the shaft...Replace it or you chance scoring and possibly braking the shaft (extremely expensive repair).
as far as life, mine was just about 26 years old before it needed to be replaced. It depends a lot on your alignment.
You have a Bravo 3. That is an Inboard/Outboard. Do they have cutlass bearings?
Most of the issues brought up look like they are for inboard engines and drive components. Am I wrong???
I don't know anything about I/O's, but I cannot figure out where there would be a cutlass bearing in one.
I have ran outboards for years and there were no cutlass bearings in them. How could there be any in an I/O?
Cutlas bearings, I believe, are only found on inboards, in the strut holding the shaft. I could be wrong.
My boat was recently hauled and the first thing I did while the bearing was still moist was check for any movment. In the pass when replacing a CB, I would re-install the new one with about a 1/4" left extending pass the strut. This allows a gripping surface when next time comes.
El Sea
I'm guessing the poster is referring to a Gimble Bearing, not Cutlass Bearing.
You can't really rely on how the shaft is sitting in the cutlass bearing at haulout because alignment won't be true in this situation.
Bravo III and all I/O drives have no cutlass bearing. A cutlass bearing is only on inboard shaft drives where the shaft passes through the strut or sometimes where it passes through the hull.
Brian
