I've used a Davis Instruments Mega-Light as a separate anchor light for about seven years now. The excellent fresnel lens and OEM incandescent light bulb make this a 2nm anchor light with an unbeatable .110 amp draw. Photocell switch for auto off/on.
Davis Instruments Mega-Light with Marine Beam LED installed.
This weekend I replaced the original Davis Instruments incandescent bulb (still working) with a LED replacement from Marine Beam. The Megalight was several times brighter with the LED replacement and according to specs: pulled nearly half the amp draw (.060 amps).
OEM incandescent bulb
Marine Beam LED replacement bulb
These are cellphone photos taken about five minutes apart. The LED replacement light has a higher color temperature and actually looks white/blue. I could look at the original bulb comfortably from a distance of six feet. The LED version was too bright to look at for long.
Boatfix sells the Mega-Light:
http://www.boatfix.com/shop3/store/listitems.asp?idCategory=445
Details on Mega-Light models:
http://www.davisnet.com/marine/products/lighting.asp
Marine Beam LED replacement bulb:
http://www.marinebeam.com/dameledre.html
Important Note: There are three models of the Mega-Light. Use the Mega-Light Masthead model if you want a hard-wired installation. It comes with 12" of wire for hook-ups. The Masthead model is shown further down this thead.
The Mega-Light shown above is the Utility model and it comes wired with a 12-volt plug. The cable on the 12-volt plug models of the Mega-Light have very tiny gauge wire that is more difficult to use for making electrical connections. You can use the Utility model for a hard-wired installation as I did but during the wiring you will wish you had the Masthead model instead.
