DAVITS - NEED HELP FAST!!!
I am at the Annapolis Powerboat show and I am very interested in the new Back Cove 37 - we are close to agreement on price and I want to buy the boat. Problem is I need a davit system where I can leave my 4hp on the 8.5 Zodiac. swim platform is about 11.5 wide, 28" deep and 15" off water. BUT the transom door is centerline and opens OUTWARD. Door is about 22" across. I need use of the transom door on an almost daiy basis AND move about the swim platform, at least enough for docking without having to lower dinghy each time. Oh and I have a finger on each side of the boat so I can't utilize a side loading system.
The Weaver won't work due to the door opening outward and the stand-off brackets blocking movement around the platform everytime you dock unless you put the dinghy down each time.
The Hurley Davits would be great if the door open inward or if the platform was not so shallow. The St. Croix MAY be an option,but i dont know the system.
Any ideas????
Need help fast
it's very hard to store a dink on a boat that size... personally i would prefer a roll up that you store somewhere and inflate on demand, I used to do that on a 37 footer years ago, it worked pretty well.
StCroix davits work but it's always going to be in the way.
or, looking at the pictures,i wonder if there is a way to flip the door to open inward? maybe not since the opening has is a little more narrow inside than outside, byutr maybe Back Cove can do something about it. I prefer the door to open inside anyway, jsut in case it's not latch properly it'cant swing out if someone leans on it.
btw.. what a gorgeous boat! I wished we'd see more of these on the water!
Have you considered a Freedomlift (dot) com
This unit will sit back towards the tail end of your swim platform & swing out & down into the water. They were asking for $15,000 plus installation but I'll bet the price has come down plus your dingy is a lot lighter then I was using?
Question...what does being on the swimplateform gain for you when docking? The cleats are up on gunnels in each cornor.
Good luck
Niles
Bob-
First off congrats on even considering such a fine boat, I spent some significant time looking at those in Newport. Its high on my list of next boats.
Re the davits, I think your stuck with the St Croix type systems, but I think you may need to talk to the factory to see if the transom will take the weight. This was the system that they used on all of the Little Harbors like mine, but they had to install a mounting braket off the transom. I believe this was fairly beefed up from behind.
There are some other brands other than St. Croix that have similar set ups, but I can't think of the names. Roskely and Olsen or something like that and a few others.
If the boat your considering has the stern thruster, I doubt a platform type lift would be feasable.
Good luck with the boat
Dan
i believe the weight of the freedom lift placed that far aft on a boat that size is going to be an issue with how the boat planes, or if it can plane at all when the lift has the tender in it.
To all, as to why I need the engine permanently in place, I can't inflate deflate a raft everytime or load the engine, I can't jump over the gunwhale and accordingly need the platform with easy access to both sides. As alluded to in the tag. I have Parkinsons Disease at 51 and need an easy way to get around the boat and I don't jump over lifelines any longer, I still move but just a little slower. I only tell you this in case you know someone with PD. Please tell them it is NOT the end of the world, just a new one. I am still smiling, having a great time, and boat shopping.
Please, I will take any ideas you have, crazy ideas are plus, an oulandish earns you a new viritual yacht of your choice. Anything.
bob
My suggestion is that you speak to the manufacturer about a custom extended swim platform so you have more room to mount various davit options and still have room to open the door.
Extended swim platforms are quite common and either aftermarket or custom from the factory would solve a lot of issues.
