De-Flating Inflatable
Crestmere
I have an infatable by Zodiac that as developed a small leak in the Stdb pontoon (noticable loss of pressure w/in 15-20 minutes). I pumped it up full and then gave it a good soapy wash inside and out in hopes of finding the hole(s)via bubbles that would be produced, but to no avail. I tried it several times, yet no bubbles could be seen.
Anyone have any suggestions/ideas as to trace the source of the leak? Thanks
The soap method is best.
An alternative is to get a tube ( hose, or paper towel spindle ) and while holding one end to the ear, run the other end over the whole surface, listening for that telltale hiss.
Check the valve assembly first.
Agree that valves are primary suspect area--and an easy fix--since you can replace the entire valve. The next area to look at is the seams--If there are floor boards, or an inflatable floor, leave this out, as you inflate the boat--this gives access to the seam at the bottom of the inside of the boat, in case there is a puncture there. 15 minutes is a very siginifcant leak and should be obvious. Make the soapy water farily concentrated, and start by putting a dabble over each valve and seams. Don't "wash" all of the boat.
Thanks guys. The floor was removed and I checked the valves.... in fact I filled the interior up (like a tub)with clean water to check just that (the seams inside as well as the valves) and guess what? no bubbles from any interior seams nor the valves. Gotta be outside or along the bottom.
I'll try again with a stronger solution of soap. Keep your fingers crossed for me!
