Well, I did some investigative work tonight through the existing foam filled holes. I also have a stringer plan. The most significant damage is where wellcraft used wood screws throught the fiberglass cover to attach the rear transom wall to the deck. There is no foam hole there for injection and I haven't drilled it out yet. I used a borescope that I have with a 90 degree mirror. I popped out 4 injection plugs (what a stupid idea, they drilled through the fiberglass and used foam to seal the perforations. In several cases the foam plugs were hardened and loose in the drilled hole. Between the screws in the deck and the foam plugs (added to this is the side of the boat with the transom entry ladder - everyone wet into the boat) and it is no surprise where the deck rotted. Here is the interesting part. The plywood decking appears to be very thin in this area. I would say 1/2" max with some deterioration. I can feel and remove foam in multiple places. All wood is dry and foam does not appear to have moisture content. There is about 3/4" of air space between the foam and bottom of the plywood. An accelerated degree of rot is in place around the holes and screw locations (no surprise).
The decking damage is not even and is sporadic over about a 16" x 24" area. No surprise, thinnest at fastener locations or foam plug locations. It is definitely not cored. There is really only one stringer location anywhere around. Here is where I get a little weak legged on cutting through the deck. There are spots that are OK and spots that are not OK. Given the air space between the foam and ply, I am not sure that I will have a good area to attach the new decking to. There is not a good stringer area to attach to without my adding some cross braces. This is kind hard to explain, but I am concerned in this back boxed corner to find enough to get ahold of to patch the deck. If I drill a few holes and don't find residual moisture (remember, screw holes and foam plugs were allowing some drying effect) would polyurethane foam provide enough support to give me a stiff floor?
Now I know that this is not the "right" fix, but hell it is a $6,0000 boat and it is not our dream yacht. It won't last (in our house) more than a few more years (but I don't want to screw someone I sell it to either). Here is why I am wondering if this is OK. What I am seeing so far is that water has slowly passed the screws and plugs just enough to saturate the ply and cause it to deteriorate over time in a very localized fashion. What if it never made it to the foam as evidanced by my inspection in multiple locations.
So again, given the localized effect, I am wondering if the foam would fill the 3/4" void and provide enough support to stiffen the deck. And YES, I know part of this is justification, but I have a bad feeling about cutting out the deck in the absence of finding evidance of water in the foam. I still very much appreciate all of the dialog. I don't want you to think I am not listening, but I have a funny feeling about whipping out the rotozip.
