Depth finders
mx8
I`m going to replace my depth finder, it won`t read under 5-6 ft of water, which I feel is an important feature to have. I`m just looking for a simple one , 2 inch in dash to replace the one I have. My previous boat had one that you could adjust the sensitivity, this one doesn`t. Any info on models to look at or avoid?
200 KHz seems to work better in shallow water.
I have a Uniden and the faceplace came off after being outside for only 6 months. Next time I will just get the depthsounder module for my GPS chartplotter.
Avoid the Raymarine ST40. I had one, had problems (intermittant variation in depth reading is shallow water(not fish!))sent it back, they sent a differen one, smae problems. My dealer finally replaced it withan ST60. This one is rock solid and I can recomment it.
You may want to hold off for a while on any Raymarine Product, read on the web that they are having financial problems. The CEO says they will survive, but we've heard alot of that lately (IE) GM, Chrysler, et all.
I have a Lowrance X47 Fishfinder which works great as a depth finder, especially for shallow water. It is discontinued, but you may be able to find one for less than $125.00 It is basic - compact w/black and white display.
I got a hawkeye depth finder. Pretty simple and seems to work good. Good luck.
My Standard Horizon dash mount is about 9 years old and the model is no longer available. It has the shallow water and deep water settings. The shallow water setting is excellent from keel depth to at least 70'. You may want to check out the curret panel mount models.
When I replace mine I'm going to find one that reads to 1/10 of a foot. In these waters 6" can mean the difference between being aground and not.
I have a Garmin, GSD22, that goes with their network bundle and it reads fine in shallow water. Last weekend I was easing into a slip and it showed 1.6 feet. I have the unit set to a 36" offset which is my draft. It is running at 200 khz.
Niles
Thanks for the feedback, very helpful,as usual.
I just got a Faria that read depth water and air temp. I love it.
I loves Boatfix's price even more!
The small Hummingbird I have on my fishing boat works WAY better than the raymarine on my Carver. Very soon the entire raymarine system is GONZO!!
