Depth Sounder - error message
This weekend the depth sounder in my Maxum 2900 displayed what looks like an error message. It first read the depth but then started slowing flashing either "SL" or "5L". Has anyone seen this or know what this means?
If SL means signal lost, can it be reset or could it be a bad receiver? I just did some hunting around and the unit appears to be a Standard Horizon D-41BD but their site does not give this specific error message for this unit. A similar unit shows this message. For that unit it is used to set-up a "dual station." The problem is that my depth sounder does not have the buttons described in the instructions to clear the SL message.
Should reset itself when it gets a good signal.
Did you lose it after backing up or going through disturbed water?
Mybe some floating debris or weeds have gotten hung up on the transducer? Or there is come corrosion on the connection tween the transducer and the unit?
Yeah, see if the connection to the transducer is good.
If you can get to it and with the unit on, you should be able to hear it clicking if you can touch a screw driver to the transducer and the put it to or near your ear.
