Looked at a boat a couple weeks ago with Cummins 6cta 8.3 (2005) motors. This would be my first diesel.
I know this is basic stuff for many of you, but I'd rather risk asking some silly questions now, than have major issues later.
These are Cummins Diamond Series motors, so they are painted white. I noticed the turbos are discoloring to an off-white/tan color, and there are other small bits that are actually brown. These are obviously results of heat. I know turbos, exhaust, etc create heat, but is this typical, or indicative of a problem?
The second thing I noticed is that there were "diapers" under both motors, essentially covering the entire bilge floor. The boat wasn't what I'd call pristine, otherwise it would be easy to just chalk it up as a concientious owner, but instead I'm questioning whether he's dealing with issues. It did appear that general maintenance was kept up (filters all dated with changes, etc), and the diapers weren't soaked with oil or anything. The broker says that it's pretty common to see this in diesel engine rooms. A line of crap, or reality?
It's typical around here to perform oil changes, etc before going into storage for the winter. Assuming that happened, is an oil analysis a waste of money with fresh oil in the motors? I've been told to have a blow-by test performed to account for that. Again, good idea?
Finally, any general feedback on the Cummins 6cta 8.3 450hp/480hp engines?
This was just a first once-over visit and I will definitely do a sea trial and have a full survey with diesel tech before any purchase, but want to be a comfortable I undertand what I'm seeing before ever getting to that point.
Thank you!
Thank you!
