Dingy Regulation?
fountain27
Are you required to carry a throwable in addition to the 1 lifejacket per person?
Second question: While I never have a sip of alcohol while operating my main boat, but the admiral and I often pack a little cooler and have a couple of beers while we explore. I am assuming since the dingy is powered it falls under BUI laws. Is this correct?
Anyone every been stopped while on their dingy?
I'd suspect you're right on all points; though I've never been stopped.
Concur with Willie. A dink with an outboard is a motorboat. Same rules, titling, registration, equipment, etc.
In FL the BUI percentage is same for boat as auto unless owner is licensed captain, then less. Higher degree of responsibility. Difference at least in FL there is no Open Container law for boats as there is for cars. You my Drink but you may not Be Drunk .08. Best to just not drink in a moving vessel.
Under 16' it does not require a throwable. ALL other regs apply.
" I am assuming since the dingy is powered it falls under BUI laws. Is this correct?"
Yes
"Anyone every been stopped while on their dingy?"
Yes
