Originally posted by PortHoleDiver
I decided to go with the drippless seals due to the assesability of the packing. I have a 300 sedan bridge, SeaRay. they don't give you any room to work. Last mechanic was about 90 lbs and 5'6. me I'm 6' 230. I can't fit to get under the engine. All I can see is a stream coming from the packing nut. Have had these done three times in two years and bildge is always wet. I will check with the yards when I have it hauled and make sure they check the shafts. When you had to have your shafts smoothed what did that run you? Just looking for the best place to have this done in the clearlake texas area. Also, someone mentioned to get a crossover hose installed also.This I plan on doing. Hopefully pss will work for me. I really don't know what price to expect for labor, or what would be reasonable. I have 1.5" shafts and I believe the componets are 250.00 per engine. Installation?????? Anyone got any ideas??
