Dock Line Size
gcolton
Well-known member
I am having a debate with myself on what diameter dock lines I should get. I am planning on getting a new set of double braided line and I cannot decide between 1/2" and 5/8".
This is for my 31ft. Pursuit.
If it was not for wanting to have double lines during times of potential hurricanes I would go with 5/8" with no hesitation. However, I an concerned that this will put too much rope on the cleats which also have spring lines.
Does anyone think that using 1/2" double braided line would be undersizing? Or maybe one set of 5/8" and one set of 1/2"?
G
I think that 1/2" would be fine. or perhasp 1/2 bow and stern lines with 5/8 spring?
I/2" should be fine. I used them on my old 31. I Just put new 5/8 on the 34. They are significantly larger. However ,I would think you would get double 5/8 on your cleats without a problem.
I use 25' x 5/8" on my Tiara 32 Open. We weigh about 18,000-19,000 pounds. I do not double line any more during severe T-storms and have had no problems.
I had 5/8" on a 32' This year I changed to 1/2", so far so good.
either one is strong enough, which size fits your cleats better? go with that one.
I love extra safety measures, so I'd go with the 5/8" if there is any chance of high winds and/or a strong tidal/current flow.
I use 1/2" lines with my 35', 18,000# houseboat. If there's a hurricane on the way I double up.
Off the top of my head I do not know the cleat size. I will have to measure the next time I am at the boat.
I am getting ready to change marinas so that is why I am probably going to get all new lines. The current spot I have on base would be intolerable in a storm. Moving to an offbase marine in Shalimar which seems to be well protected and I can get a slip wide enough to have some slack in the lines to help protect against tidal changes.
G
Not what you asked about- but, as I understand, the 3 strand nylon have more stretch and are less prone to "snagging" than the double braid. As every little bit counts,to relieve a little pressure on cleats in windy weather, would the 3 strand be a better choice?? I use 5/8" on my 34' Searay, but may have a problem doubling up. Have never needed to, so don't really know. Just my 2c. Good luck.
Ron
I use 5/8 on my 31. The 8" cleats can handle two lines.
FYI, two line/rope mfg. sites have this same table.
Boat
Length Dock Line
Up to 20' 3/8 In.
20'-30' 1/2 In
30'-35' 1/2 In
35'-40' 1/2 In
40'-45' 5/8 In
45'-55' 5/8 In
55'-65' 3/4 In
I use 1/2 inch for my 29' so that I can double the lines if necessary. But I do have two short 5/8" double braided lines on the stern since I do not have the option of crossing the lines. For those two I installed rubber line snubbers to allow for some spring action.
Mabbot, what type of line is that table for:double braided, single braided, 3 strand, or what?
G
All those responses & only a few were concerned about cleat size first!!!! There is no point in any size if the line can't do at least a once around the base of the cleat, a complete "8" then a half hitch. Far too many builders put waaay undersized cleats & not enough cleats on boats & then make things worse by putting them in dumb places.
