Docking/Boat Handling Question??
Prospective
The Setup:
Boat is a 30ft twin I/O express. Typical bow, spring and stern cleats. My new slip is a finger on the port side and pilings to starboard followed by next slip then another finger. Width of slip is about 14' so I can't reach pilings if boat is along finger. Slip is 36ft deep. Only safe on/off for boat is swim platform and that's where shore power hookup is so for those reasons I prefer to back in.
The problem:
The slip is in a tidal river with a significant rip incoming and outgoing perpendicular to my slip. Outgoing is not a problem as I can get it spun around and backed in pretty quick and the rip naturaly lays me onto my finger. The trick is on incoming tide. I can get it spun around and backed maybe 1/4 to 1/2 in but then I am well off the finger and bouncing off the pilings seperating me from the next boat.
My current theory:
I spin around and back down tight to finger and wife steps off with stern line. She gets it around mid cleat on finger. By this time bow has drifted off finger. I have her lock off stern line and power forward which brings bow up to dock. Then she moves to boats spring cleat and take line which is already rigged and ties off to forward cleat on finger. I then hold boat to finger by backing down on spring while she unties stern line and tosses back onto boat so as not to have slack fouling prop. Then she goes back to spring and eases thru cleat on finger as I back down. If I mark the line so the she knows how far back ease, she can stop at mark. Then ties off spring, grabs bow line on boat, ties off, then grabs stern line and ties off.
Question:
I hope what I am thinking made sense. If so I am wondering if what I'm planing is the way to go or if there is a better/safer way. We've only come in a couple of times and I typically end up bouncing against the piers as we back and fill. No damage but it ain't real pretty.
Just looking for thoughts. Sequence of events upon leaving as tide pushes me off would also be helpful.
I think I picture your situation, but why not have her step off the stern with a line from your midship cleat and let her fasten that to the middle cleat of your slip. That eliminates the tieing, untieing and throwing of the stern line. You could then power forward to straighten out the boat. Once straight, I would think you could back down with her controlling the spring line.
As always, this is just an opinion, it's hard to be exact without seeing the actual conditions. I'm sure that with more practice, it will get easier too.
assuming they're wood pilings, there is really nothing wrong with laying against them and/or pivot of the pilings.
sounds to me like you are not leaving your lines at your slip which makes it a little more complicated. I personally really don't like relying on someone jumping off the boat. sooner or later, she will miss the step or something will happen and she'll end up in the drink...
what i woudl do is try to anticipate the current as much as possible and get the boat in, laying agaisnt the pilings on stbd. From there, you shoudl be able to reach the lines that you left on the dock with a boat hook. Secure the spring line first, leading aft from the dock to your mid ship cleat. Then you can either pull the boa in place with the other lines or just put it in reverse to spring in place agianst the finger.
for springs I always use the eye on the boat cleat so that i know that no matter what i will not back in too far and into the dock. for stern and bow, i use the bitter end on the boat so that i can work the lines agaisnt the cleat or adust the lines from the boat.
leaving your line and using the spring as i explained woudl allow you to get it in alone and more importantly not rely on your wife doing acrobatics.
But dont' be afarid on the pilings, that's what pilings and rub rails are for.
Leave a line pretied to the piling exactly the right length with a loop on the bitter end. Get the line on the midship cleat. If necessary you can pull perpendicular to the pier facing into the current to grab the line. With the spring line on the up current cleat back in. When it is tight, cut the wheel so the stern swings toward the pier. Alternatively, if the pier is long enough, leave a short line on the up current piling. Pick up the line, attach to spring cleat, go forward and turn wheel to swing stern toward pier. Plan C, if you can't get to the midship cleat, leave a line tied from the midship cleat to the stern cleat. Release at stern and attach to piling.
Don't have her jumping off the boat, like Pascal says, sooner or later she's going to fall in and then some really bad stuff can happen.
Get a boat hook and use it to grab a cleat or push off the piling.
Always try to back against the current, you will be able to manuever much better.
You can also run a tight line, or wire cable with hose over it, between the pilings on your stbd side so you can lay against the line without worrying about slipping between them and hitting the boat next to you.
This reads pretty much like what I do.
My boat is about the size of yours except with twin inboards. I keep my lines tied to the dock/pilings. When I come in my boat hook is very useful for reaching the lines and then all I (or my helper) had to do is slip the eyes onto the cleats.
My finger pier is very short so we essentially have three pilings on one side and the pier and two pilings on the other.
George
I had the same issue for 5 years but had no down-current piles to lean on....
Leave a forward springline on the dock and have that the first line attached to mid-ships cleat.
You can then continue to back down and the spring will help snug you right into the finger.
Bill made a good point, in cases where there is only one piling at the slip entrance to keep you from the other guy, run a line from that piling to the dock and pull it as tight as you can so that the boat leans on that line and not on the neighbor.
Thanks for all the great advice. I feel like I'm on the right track. And I appreciate the thought that laying against the pilings is not too big a deal. I feel sloppy but in the end, no damage and we end up on the dock.
I also like the idea of coming in perpendicular to the slip heading up current and attaching and grabing a pre-tied spring. Then I could pivot in while backing down.
I appreciate the thoughts on leaving the lines on the dock and not having my wife stepping off the back. My challenge is that I don't have good access to my spring cleat from on board. It's a lousy design but a short coming to many express boats as I've learned. The spring cleat is amid ship with a very tight/dangerous walkway. So I've left it attached to the boat and had someone grap it from the dock. And I cant reach it by reaching over a too tall windshield. I do understand that stepping off the platform is not the best option but I don't have any problem getting it right up to the dock for her to step off. And it seems safer than having her do some risky manuver to grab a line with a boat hook and one handed hook it over my spring cleat, all while holding onto the the grab rail on my radar arch trying to stay on board.
I would like to add a "wrinkle" to this discussion. I have a VERY similar docking situation, except add in a nice cross wind as well. EXCEPT I have NO PILINGS anywhere...just a sail boat 12" off my Starboard.
I have the same issue with the midship cleat...no easy/fast access. But I do leave my lines attached to the dock and in the correct position...
Any more thoughts as best method to handle?
Perhaps you could leave a short line attached to you midship cleat that leads into your cockpit that you can attach your permanent spring to as you come in the slip.
As to the sailboat on your stbd side, put out fenders in case you end up next to it.
Odd.. I saw a good size Searay do just that at our marina last weekend. Lady stepped off the swim platform and got caught in no-man's land. One foot on the platform, one on the dock doing a split. In she went and away she went right under the slip..
i saw something similar a couple of years back, with a guy coming in alongside a dock. Wife at the bow, climbed over the rail, missed the dock and fell in the drink. Her head barely missed the dock...
i dont 'want to get started on side decks :) Bill's suggestion woudl work, you could even used a snap ring to quickly hook up the spring to the short line and not waste time trying to tie them together. OR, depending on how the cleat is setup, just pass a longer spring line behind the cleat and tie the line to a stern cleat. This way, your midship cleat is used a chock but that's still where the pivot point will be when you spring in.
" I feel sloppy but in the end, no damage and we end up on the dock."
Pilings are your friend; As long as you INTEND to lay against them, there's nothing sloppy about it. It's when you try to do something else and don't succeed that you feel sloppy.
Great suggestions and learning to use the spring line is just key.
Totally agree on not having anybody "jump" off the boat before you are already tied down with engines off.
Under the slip is better than under the boat and into the prop which happened at my last Marina
I learned when my wife was pregnant, and I found its really best when you have buddies aboard. They'll do anything to try and "help" you (which usually is the wrong thing) and don't have any regard for the fact that even a small boat like mine weighs and has as much power as a pickup truck.
So its so much better to say hands and feet inside until I shut down.
