Docking Helm Controls
Pilotpak
I have a very tight berth, and have been thinking about a remote docking controller for my Meridian 341 (already has electronic Throttles / Shifters & Bow / Stern Thrusters). I wan't to be able to control the boat from the rear cockpit when reversing into my pen.
I really like the Yachtcontroller system, but it seems horribly overpriced, costing around 10k. Also saw Docking Master on the web but can't find any pricing on him.
Does anyone have any experience with these ?
Are there any plug-in style Thruster / Shifter controls that I could plug into the rear cockpit when reversing ?
If I recall Dockmaster was about $6000. two years ago?
if your the visibility/line of sight is bad from your uppper helm, why dont' just put a set of controls in the cockpit? with electronic controls you can probably just plug in a extra control, should be easy and fairly cheap. to back in you probably don't even need to bother with the grinders, your engines give you great side to side control as it is. but if you really want to, an extra st of joystick should be easy and cheap as well.
remotes are usually used on large boats, so a few extra thousands dont' make a big difference compared to adding it on a small boat.
Mike & I tried the Axius system whine in NC .. it was fantastic.!!
How about camera's and a monitor. One of the boaters on our dock has it and you can see the boat and dock clear.
I have the Yachtcontroller and love it. Bought it almost 2 years ago but it was quite a bit less than the 10,000 you quote even assuming your are quoting in AUS$.
I considered wired controls in the cockpit, but this does much, much more for me. I am able to operate the boat around the dock from anywhere aboard, including the side decks and foredeck. This allows me to handle lines and control the boat. It is great for picking up the anchor or a mooring.
I would highly recommend this for short handed operations and/or vessels with limited sightlines. (By the way they send me a baseball cap if you tell them I referred you!)
Pilotpak, You should not even waste your money on that stuff! I have the same boat and you will get used to her after a while, tight dock or not. I too have a tight dock and I banged her up a few times at first, but after a while I got used to her. The Meridians move quit well with the bow and stern thrusters, and you can peek over your helm form the Captains side and look down your staircase to see the port side. I just don't see any reason to spend that kind of money?? The beam is 12'6" and I have backed mine in 13' slips without any problems.You also have diesel engines which should be even easier than my gas, I have to constantly bump the throttles to make her respond, especially since I had my props turned down. Keep practicing!
Put up two sticks, on your dock, one orange, one green, align them both with your helm seat and you'll nail it every time.
That's a neat idea. Just like a channel range light.
It is how we put big jets on the centerline every time. How my wife gets in the garage as well!
I would tell you to just learn how to handle your boat better! With bow and stern thrusters that thing should be able to dance around the dock in almost any condition. Practice!Practice!Practice!
I would agree with some practice and cameras. I use cameras to back into my slip as I can't see out the back well at all. I'm in a bigger slip now, but my slip last year was actually a bit narrower than my boat at it's widest. I had to back in, and stuck out almost 20'. The camera's work, it just takes some getting used to.
On another note - docking controls would be cool.
Pilotpak: Does your boat already have dual helm stations?
If not then it should be relatively easy to install a second shift/throttle and thruster control at the back deck area. The shift/throttle should be trivial, just need to get the second control unit,find a place to fasten it down and run an electrical cable to the control boxes.
I have never had the luxury of a thruster so I have no experience but I would expect them to have a similar second helm station input to the control box.
Rod
