Docking without shore-power
carver 2557
I looking at the potential for next years docking where I would not have access to shore-power...We don't need lots of power and only on the weekends...I was thinking of maybe 2 or 3 batteries with a power inverter placed in a well ventilated dock box with a solar panel hook-up to keep the batteries charged...The most power we would need is to run the microwave on occasion, and to keep the batteries in the boat charged..what would be the preferred hook-up for something like this?...I would like to come up with something that I can plug my shore-power cord into...any thoughts?...
You can do what you are thinking and it might be kinda slick if done right...
The only thing is battery charging the boat with the dock inverter may not work so well...
Inverters are not 100% efficient so you will need more battery in the dock box than is on the boat...
Probably either 4 or 6, 6 volt golf cart batteries and the largest inverter you are willing to pay for...
The bigger the better on the inverter...I would go at least 2000 watt for 15 amps of service but bigger is better to keep the temp of the inverter down.
Then a small 30 amp Square D breaker box (on the dock box) and a 30 amp receptacle wire to the breaker for connection to the shore cord...
Or...Some inverters already have 15 amp receptacles with built in breakers...You would just need an adaptor for the 30amp shore cord end to 15 amp inverter receptacle...
The reason I say 4 to 6 batteries is they will likely have the capacity to get you thru the weekend...The Solar panel that might fit on top of the box (size) will likely not replace what you might use each day of the weekend but could catch up during the week when you are away.
Steve~
Also be sure to get a ground rod to drive into the bottom of the lake/river to attach a ground to.
Steve~
It could be done but as Steven mentioned, you really need more batteries to make it worth while. A small Honda genset mounted in a proper box for even more sound attenuation might be a better way to go.
I like the idea of the small Honda genset mounted in a proper box for even more sound attenuation...This is the way I might go, but was just tossing around the idea of a self contained power supply with the inverter...The genset would not be running that often, but I thought it would be easier and quieter if I could just plug my cord into something...
Keep in mind with a Honda in a box you will need a way to ventilate it so it won't overheat, and also need to get rid of the exaust outside too...It won't run on it's own exaust to well.
Steve~
I'm not sure why you want to put the batteries, inverter, and solar panel in a "dock box"... why not simply install everthing on the boat???
Using a solar panel to charge the dock batteries to run an inverter to run a battery charger to charge the boat batteries is going to be horribly inefficient.
Slick idea if you don't have room for additional batterys, inverter & solar panel onboard.
For different reasons I did something similar last weekend when hurricane Bill came hanging around Bermuda.
My boat is stored nearby onshore so it was no worry but it did have batterys & an inverter onboard. I went & stole a couple of batterys & the inverter. Charged up the batterys first then hooked up my own little 110 system sittng on the kitchen counter.
We got lucky & were only out of power for 12 hours so I did not need the inverter for long. Only used it to power my external modem & laptop power supply.
Had we gotten to a state where the batterys went dead the plan was to place them in the car & run a booster cable from car battery to inverter batterys whenever we went somewhere. Never needed to.
There is always a way to solve lifes little challenges.
The Honda is so quiet you can barely hear it.
Another option would be to take an 18 HP lawnmower engine and turn it into a generator. If I recall correctly, there was an RO who was planning to do the same thing...
I know someone who has one of the "Honda Whisper Generator's", and he says you cant even hear it run...I may take a run down to the Honda Dealer this week and see what they have and hear one run...
Does anyone have experience with these "Honda Whisper Generator's"?...
Do you have to remove the blades from the lawnmower???...eh...
I'd leave the blades on the mower/genrator and in the water to keep ice from forming around your hull in the winter.
juts add a few oil lamps to your idea for light and all will be fine. they provide a little heat as well for cold climates.
The honda EU2000i is NOT whisper quiet but it's not very loud either.. On the eco-throttle setting it's 53Db and will run 15 hours on one gallon of gas at 1/4 load.. You really can't beat it except for possibly the new Yamaha which is very similar. I may even bring mine on the new MY368 to avoid running the Onan diesel genset all the time which burns .5 gallons of diesel an hour at 25% load.
A small garden tractor can be used.
Strap it to your swim platform.
Simply attach a pulley to the blade shaft and attach it to a small generator with a fan belt.
A side benefit to this is you can easily contract to mow lawns on Block Island to cover your trip expenses, or finance an even further trip out to Bermuda.
Where you going next year Wayne? Thought you were coming down with us?
Seems like all that hardware would end up costing more than just going back to a dock with shore power.
Indeed. Solar panels are not exactly cheap yet. Perhaps there are small ones that will trickle charge and keep them up but it depends how much load there is and how long the sun shines. There was a couple in a 25 foot sailboat that had limited success on the hook. Everytime they were on the hook the clouds came out, and when they hit a marina to charge up the sun was bright.
And they had 4 rather large panels as I recall. Probably not very cheap.
A small genny is most likely going to be cheaper. Regardless it's going to be less complex and easier to deal with.
By the way where will you mount the panels and will the marina let you?
I think I know where you can get a good deal on an old tractor with a beefy generator you can keep it on the swim platform like mention above and maybe in your spare time you can mow the lawn at the marina for an even better deal. In the winter you can plow driveways with and make enough money to keep the boat at a slip with power. But honestly I like the idea of a self contain battery box however it would be costly. As mentioned solar cells large enough to maintain a charge would not be cheap but still a cool concept.
Is there any reason why you think an 18hp engine is needed? It seems overkill. I would think a 2-3hp engine connected to an alternator would be able to supply sufficient DC power to charge batteries plus provide power to run an inverter.
