doing the loop
dlane
doing the loop great lakes to venice florida
44 ft AC sea ray any info from previous loopers
would be appreciated. Gas motor, leaving mid august. Any tips marinas, things to see things to avoid. thanks
If i'm not mistaken, there are books/travel guides for the great loop. You might want to look into them.
If you have a 44 footer with gas engines, I hope you have budgeted a very large amount of cash for fuel.
there are quite a few websites dedicated to this subject. before you get your engines going, if your boat is a sedan bridge check your overall ht. i believe the limiting bridge is in chicago and is either 14 or 16 feet. google the subject, its commonly refered to as "the great loop"
i can tell you that avoiding the missisipi river and using the TenTom waterway is good advice.
sounds like a wonderfull trip, i'm envious. :-)
Go to www.greatloop.com which is the site for the America'sGreat Loop Cruisers Asso. There are loads of personal web sites with all the info you will ever want to know.
There are many good publications. Skipper Bob is a publishing company owned by Waterway Guides. They produce Great Loop specific cruising guides. Their website is http://skipperbob.net/
We are starting our Loop trip in mid-August from Knoxville. Are you going clockwise or counter-clockwise?
I would think going counter clockwise is the better way to go so you aren't fighting river currents going north. I'm guessing both speed and fuel economy will suffer greatly going clockwise.
Thanks so much, have been researching for 1 year and planning Just wanted what would be intersting and areas to avoid
I did the loop clockwise. There can be an advantage as going against the current gives you more control. However it really does not matter as you will be going against the current at several points either way. The Tenn Tom is the better way as opposed to the Mississippi however many will find it as a challenge and just as interesting. The controling height is a bridge on the Chicago ship canal at 19'1". It can be even higher during low water times or whenever the water control people need to lower the level for expected heavy rains. The best way to avoid any problems is to have a boat that will clear all obstacles. Extending the loop to include The Trent Severn, the Rediou, Ottawa River and the Thousand island area of the St Lawrence River will make it an even better trip. Canada is great. Take the time to enjoy the sights. At the cost of fuel rushing through it will only cost money with little enjoyment. You should have enough fuel aboard to go at least 250 to 300 miles without a fill. There are a couple of areas you will need to make special arrangements for a truck to meet if you cannot. I believe the best of the trip was the interesting boaters we met along the way. Many have become long time friends.
The absolute best advice in the world I can give you is TAKE ME WITH YOU!!
