Dremel tool recommendation?
JoeBTB
I'm thinking about getting a cordless rotary tool, for various miscellaneous uses. I was looking at a Chicago Electric 9.6 volt cordless (92880-3VGA) from Harbor Freight, as it is much cheaper than the 10 volt Dremel brand.
Eventually, I'll probably be using it to chase down a million and one cosmetic gel coat cracks.
Anyone with recommendations or thoughts on whether this tool would hold up for something like that? I haven't really started research spider crack repair, but my understanding is a dremel is the way to go.
Never heard of a cordless dremel. If I may, let me play devils advocate. Why cordless? Will the batteries sustain the load and how much does it weigh?
As a comparison, mine is a corded vary speed from 5K to 30K RPM. It also has an extension ?three foot? that allows you to get into tight places. It was less than $100 several years ago.
HTH
Cordless seems more convenient, but yes, that is one of the things I'm wondering about -- do the cordless versions handle a decent load, enough to work gelcoat cracks. I assume gelcoat isn't any more of a load than cutting things. The Harbor Freight version is $40, and comes with the extension and a bunch of bits, not sure what battery life is like. The Dremel version for about $85 lasts 3 hours per charge. They are both variable speed.
I have the cordless dremel and it is totally worthless. get 1 with a cord
Dremmel does make a cordless but it's not powerful and charge doesn't last. I have the regular one and you can use it with a small 400 Watt inverter. Keep it away from your gel coat, even on the slowest speed it's way too fast and will burn it.
I 2nd the Dremel with cord. I used mine (variable speed) with the dental burr to fix some gel coat cracks. It opened them up well and gave a good inverted "V" to accept the filler.
Have you folks used such small variable speed drills to polish acrylic materials?
I have glazed headlamp covers on my old Cadillac headlamps. I'd like to try to polish the scratches out. UV and car wash over the years has done a heavy scratch job on upper portions of what was once clear "plastic". I've heard that a Dremel and toothpaste and some polishing gizmo might work.
Any thoughts ? Thanks
Appreciate any thoughts.
Acrylic polishes very well. For polishing "heavy" scratches use 3M Finesse-It II Finishing Compound followed by Plast-X from Meguiars. If it's really badly scratched you can even wet-sand first, working your way up to 1500 or 2000 grit, then go to polishing. For polishing use a normal rotary buffer - drill powered if you don't have one. If it's a really small part, too small for a normal rotary or drill polisher, then a Dremel Tool should work. Just keep things moist and wet - don't let it dry out.
Toothpaste is ultrafine and won't do much to remove heavy scratches.
I have the 10.6 volt Lithium Ion Dremel. It is a fabulous little device. Great power, lots of accesories, I use a B&D Wizard flex cable with it and anything I need more power than it's got, a cord won't help. It's time for the Roto-Zip or something equally heavy. The battery is quick charge and stays charged and ready to go all the time. For small, precision work it's great and no cord is well worth it.
One of the things with these type of tools is their speed wears them out quickly. The brushes and bearings are not long for the world. One thing I like about the Dremel is they have a nominal fee exchange program. I think it is about 25 bucks. You send them the old one, they send you a new one. I've had about 5 Dremels in my lifetime all on exchange.
I never had any tools with these new lithium ion batteries. This may be a whole new ballgame.
To me the keys are variable speed and corded. I havn't used any of the newer cordless models of rotarys. But in the cordless world, batteries wear out or get lost. Replacement batteries are usually more expensive then the tool itself. A corded, even heavily used will last along time. And again, variable speed. Way more flexability in what you can use it for.
I have a little Black and Decker Wizard Rotary Tool. It used the same 3.6volt power cell as my Black and Decker Power Screwdriver. I find it a very convenient tool for small jobs. It is two speed. Most recently I have used it to route the outline of the recessed door locks on about 8 new doors. Works fine in wood. See no reason that it would not be just as good in gel coat. See no problem with how long the power cell lasts.
G
Five? You surprise me with that one Greg.
Dremel tool is about the only place in America where the phrase "Speed Kills" is applicable.
I've gone through a Dozen or more at work.
I have replaced the Brushes and the Front bearing on one or maybe two. Mostly I just got a new one and dumped the old one in the Re-cycle bin.
Dont bother with Cordless. The Batteries are just too small to last very long.
The good part about harbor frieght tools is not feeling bad when I drop one overboard. That's about the extent of it. HF power tools aren't worth a damn. Good for a couple (literally like, two!) of light uses but not much more.
I'll second Greg's observation regarding Dremel service, the support folks in Wisconsin (not god-knows-where in China) were great, got me a replacement in two days time for one I'd roasted the hell out of digging rust out of a fender.
Regardless of brand, most small rotary tools are light-duty devices. If you're going to be grinding for more than a minute or two look into getting the flexible cable attachment for a rotozip instead. But I'm not sure I'd use either on gelcoat. The trouble with rotary tools is their tendency to walk and gouge the hell out of things. On a boat, where nothing's inexpensive, that's not usually a risk worth taking. But if you're already good with the tool, you know this. Don't make your boat a learning experience.
As for headlight crazing, try using Flitz with their ball polisher in a drill. Works wonders. Just make sure you get different wheels for metal and plastic.
I've got several rotary tools, including a few from HF and a Dremel. All work fine. The HF cordless one is great and really handy at times, but it's light duty. My cordless one is a few years old and is getting intermittent, so next time HF has one on sale, I'll pick it up and dump the old one.
The Dremel is better quality, but they wear out, too.
And, yes they can be used for fairly delicate work. I've used one to polish scratches out of my watch glass and even eye glasses., with excellent results. Now, with the eye glasses, you may change the magnafication a bit, but in my case it was a spare for work and better than dumping them. You can get holders that make it easier.
" The trouble with rotary tools is their tendency to walk and gouge the hell out of things. On a boat, where nothing's inexpensive, that's not usually a risk worth taking."
This is probable the most important observation on this thread. When I was doing the lock inset routing using the Wizard I was using a plastic template as a guide. Even then the tool was trying, and succeeded some, to walk.
I do not know how you would ever keep it on track by hand.
G
The Li-on Dremel is fully variable speed. Very convenient thumbwheel that is easy to control.
