Drill pumps
dritter
Anyone use a drill pump to change oil? I used the pressurized ones before, but was looking at the ones that attach to the drill.
I have never liked them. the vacuum type or permanant install are my preference.
Never had any luck with them to move even water. The manual suction type work very well for a reasonable price. The electronic ones are pricey, but fast and efficient. AustinPaul sent me some info on a preluber that can be set up as an oil changer as well.
Tried one and it was completely useless. Would have taken a week to pump all the oil out at that rate.
used one for 2 or 3 oil changes, there's better out there. the drill pump has to be held in your hand so it doesn't spin, unless you can rig something more crafty. it gets hot. your hands will be full holding the drill/drill press, it has hoses hanging off of it that you want to be very careful with, you'll have another tank near your feet to collect oil, you have to sit there with it and wait, etc. it will make a really oily and trippy mess if you let the drill press spin and pull the hoses out, i'm still finding oil in stange places.
vacuum pumps are much easier, oil boy extractor it might be called.
KiDa...care to post that info here?
Tey're a mess to use and take forever. I use a vacuum type extractor & I get 4-5 quarts out in just a few moments.
The Oil Boy Extractor...that's the way to go. Pump the handle 8-10 times and walk away while it does its thing.
Thanks for the info. I used to use a friends vacuum pump, but he moved away and was looking at the drill pumps. I will order a vacuum today.
I use one all the time. IMO it works a whole lot better than the "oil change pumps" the marine stores sell. Properly set up it's no messier than any other system. The "oil boy extractor" may work better, but not for the price. My engine holds 3 gallons, more than the Oil Boy, so if I went that route I'd have to pump out what I could, empty the Oil Boy, then pump out some more. With the drill pump and a couple hoses I pump the oil to a 5 gal can in a single pass.
Note I do NOT use the dipstick hole. I have a hose fitted to the crankcase drain and pump it out that way.
Originally posted by stmbtwle
...Note I do NOT use the dipstick hole. I have a hose fitted to the crankcase drain and pump it out that way.
In your case the drill pump would work well as gravity is tending to part of the suction side of the equation.
if you decide to go 'electric'.. the $20 Chinese 12-volt job works well for me.. usually does it's job within 5 minutes.
I have looked at the electric 12V also. I see boat fix has many to choose from. I know the oil boy has been mentioned, but I also was looking at the top side changer. Metal with a pump and clear vacuum hose.
I've burned out two of those rb2@gr5t#$%rb2@gr5t#$ $20 Chinese pumps trying to change oil... That's when I went with the drill pump and the pumpout hose. Only problem is you have to get the oil out BEFORE you install the hose.... But it's worth the one-time initial hassle. Changed oil today, with the drill pump and the battery-powered drill I keep on the boat. The filter was a bigger mess than the pump.
I have yet to use this, just put it together. Already had the drill pump and an extra bucket. Spent $10 on the rest of the parts, thought it was worth a try. The hardest part as mentioned before was holding the pump and the drill and trying not to spill all at the same time. This will hold the drill up and contain the oil all at once. Would like to add an oil pan connection to this as well to pump out from the bottom. What has everyone used in place of the drain plug? I am assuming some sort of threaded nipple with a shut off valve and some fuel hose...
