Dropping RPM
Cyprox
I have been having problems with a 225 HP Mercury 2006 4 stroke.
As long as I go less than 3000 RPM all is fine and dandy. To go on plane I have to rev up to 5000 RPM and then drop back to about 4400 RPM which is cruise speed. Lately the RPMs drop down to about 3500 and fluctuates up and down several hundreds RPMs with the boat going off plane. Took it to the local mechanic. Was told there was water in the water separator filter. He changed it and recommended a RACOR water filter whioch I placed. Took the boat out today (also put Mercury "dry gas") in the tank and still have the same problems. It feels as if it is starving for fuel. If I bring it back to idle then rev it up again it does fine for a few minutes prior to the drop in RPM occurring again. Any thoughts?
Sounds like water or some kind of fuel contamination to me. Could there be another filter down stream of the Racor?
There was in the engine, which was full of water. That was replaced prior to the RACOR being placed.
If the second filter was replaced prior as you stated and you ran the engine, it is probably contaminated again.
Sounds like a fuel restriction. Check the on engine filter again to see if it is contaminated. Are you running E-10 gas?
When the RPM drop occurs, check your primer bulb to see if it is losing prime.
Break the issue down to engine side versus supply side. Change out the on engine fule filter so you are starting fresh. Pick up a 5 gallon (or bigger) portable tank (fill it from some other place than where you last got gas), some fuel lines, an inline filter, and a primer bulb. Connect your engine to the protable fuel supply and go for a ride. If the RPM drop occurs, your problem is engine side. If you run fine, your problem is supply side.
Once the problem is isolated, you can further diagnose.
One last question - Are you running a Verado?
if you had water once you probably havent gotten rid of all of it. dont look for more problems until you are certain that the old one is fixed. empty all the filters again and see if there is water in them. It is not necessary to replace them just pour the gas into a container and look for water. Filter the gas through a piece of cloth to remove water and put it back into the tank.
Thank you guys for the help. Had the mechanic look at i under way. Fuel flow was restricted. he believes the fuel filter might be dirty. WIll be taking the boat to his shop on Tuesday, and he'll take it apart and replace it. Hope that solves the problem.
