Dry Tortugas
Aquaholic101
Thinking about trailering my boat to Key West and making a trip to Dry Tortugas. Heres the boat 24 WA W/ 225 merc has 140 gallon tank. Cruising burns about 10 g/hr at 24 knots. Is this doable or am I insane. Concerns or rec's appreciated
i'd go to Block Island in a bowrider before trying the Tortugas in a 24 footer !
you have the range, but it's a long way from home if something happens and not a lot of traffic... and you're out of range of VHF and Cel.
maybe not insane but not very wise unless you have a sat phone and can be sure the weather window is perfect.
I went out there on one of the charters (60+ cat) and was looking for the life jackets. The entire cabin cleared out to yak leaving only me, the admiral and a few crew members left.
It can get nasty really fast. Take one of the sea planes and enjoy the day.
Considering all the hassel in getting the boat to Key West, I'd agree that a seaplane ride out and back is the way to go. Anything else will run a high degree of uncomfort/unsafe times.
Flew out there once on a Navy Helicopter. You're right, a long way from civilization.
That was an easy decision Thanks....
Bahamas would be easy but man its cheaper to fly there and rent a boat..
It'll cost you $100+ each way for fuel or about the same as the fare on the Fastcat previously mentioned. The floatplane that leaves from KW airport will cost about twice that.
Staying out over night and fishing the Dry Tortugas waters, however, is priceless.
It does not get "nasty really fast". The tour operators are on a schedule and it takes a LOT for them to stay in port and refund your money.
The start of the Gulf Stream is somewhere off South America. It runs up past the Yucatan Pennisula, sweeps around the Gulf of Mexico and comes south around the Dry Tortugas. As is the case with the Gulf Stream off FL, a wind blowing against that current will stack the waves up to where it gets very uncomfortable between Rebecca Shoals and the Dry Tortugas, a stretch of about 15 miles. Every thing else is well protected by keys west of Key West and by shallow waters.
i have personally made that run in my boat. i loved it. there is nothing like sleeping the night at ft jefferson.
as far as teh capabilites of your 24' yes and no. could it make it, yes. could you have a great trip,yes.
it is the what ifs that far out number the goods points with your boat.
Sounds like your getting good advice above, but how about heading out with a group and bigger boats with you. Hear about that going to the Bahamas quite a bit., just a suggestion, hope it helps.
Jon
