Dynatrail tires?
waterskier_69
I need to replace one of the tires on my trailer. Goodyear says the Marathons that I have were replaced with something similar. The problem is they are backordered and their location is out of my way.
Les Schwab sells something called a Dynatrail. I have no experience with these. I saw an RV forum that says these are made by the same company as Carlisle and I have heard bad things about Carlisle on this forum. Does anyone have any experience with the Dynatrail? I do know that Les Schwab stands behind what they sell and if a certain brand showed an unusual number of defects they would find something else.
Never heard of them, but that doesn't mean they're no good. Carlisles, I know, are no good so I won't recommend them. If you can't wait for the Marathon, try the Dynatrail since you have confidence in the dealer.
Just be damned sure this tire rated for trailer service.
-edit
Oh, one other thing...if you have radials then make sure you replace with a radial...if they're bias ply, use a bias ply. NEVER mix different type tires!
Thanks Mike. Yes it is an "ST" trailer rated radial. After the first post I was able to see photos of the Carlisle vs. the Dynatrail and the tread is NOT the same, which is encouraging.
Tread pattern isn't the problem, it's the general construction...how the plies are wrapped and integrated to the chord. Goodyear and others do a great job at building a tire. Carlisles have a nasty habit of "delamming"...the tread separates from the body of the tire.
