Eisenglass Winter Storage
hamster
Last fall, I cleaned my eisenglass and roll them up into pouches I made for them. They looked fine for the spring launch.
Recently, I was at a winterization seminar and they suggested that the eisenglass be cleaned then stored flat. So my question is - how do you store your eisenglass for the winter - flat with sheets/blankets between layers or rolled?
Have always stored "FLAT" after cleaning & polishing. I interleaf with tissue paper; the kind used for gift wrapping. Buy it at the Dollar Store. If you do; only take in $5.00 or you will spend much more.
Joe: we have strataglas,,just a little thicker than yours, and I store it cleaned and polished on the bow bunk, with sheets (cloth) towels etc. between each piece. I do have a "damp-rid device that I keep up in that cabin over winter, and have done this for yrs. without any problems. Brought home a couple times, however with 23 panels, scratches occured, and it was more work to get them out.
In previous years I haven't had the space to store flat. For protection I've cut cotton sheets to the shape of each panel, then rolled everything and stored in the original canvas bag. The instructions on the bag actually say it's OK to roll the panels for storage; just don't FOLD them.
This year I have a garage with some flat storage space in the attic. I plan to lay everything flat with the same cotton sheets in between, then cover with a top sheet. This should make it easier to take down individual panels and polish during the off season.
I store my eisenglas in the summer flat under the matress in my guest room, after they are cleaned and polished. In the winter, they are installed in the boat's canvas. If the day is warm, I remove and store flat below in the V berth. I never, never, never roll or fold my curtains!!!!!
Flat on the aft cabin bed with beach towels between each piece.
Niles
I bought some very cheap blankets from Ikea. Like the type you get on an airplane. My curtains are flat, in a pile, with the blankets between them. I keep them in the house.
Buy flannel from the local fabric store - I was lucky a couple of years back and hit a sale - around $1.50 per yard. Cut to size and hem if you have the time and talent. Be careful with what you think are cotton sheets. Cotton is fine, but most sheets today are a poly blend - which can lead to scratches.
Thanks for the quick response to my question. It looks like the seminar had some good points. Glad I laid them flat this year. I have them on top of the mid berth cushions in the attic with each section covered. The next time they get moved will be early spring.
Joe
We hang ours over the 4" drain pipe in our basement. We use large towels both on the pipe and in between layers. The 4" pipe is large enough in diameter to keep them from getting a crease.
Flat at home under a guest bed. Put flannel material between layers. Wife doesn't like it in the house but, what the heck.
We hung them in them on clothes lines in the basement in the same orientation that they are when installed on the boat.
I don’t shrink wrap anymore, I keep my boat in the water for the winter, but I have a winter set and a summer set of both glass and canvas. I have strataglas for the summer and eisenglass for the winter. I clean polish etc, then take old soft towels and roll gently and not tight. I do the 2 sides together then the front 3. I then stand them in a closet. I agree laying flat would be the best but my method has worked fine for years now, no kinks, scratches etc.
cleaning and waxing with what kind of wax is it safe to clean and polish this with
and does it protect it from any minor scratches
I know amonia produts make the glass foggy so i have some concerns as to what is safe we just went up and put all our top flat in the V berth seperated by old flanel bed sheets
Is there anything wrong with storing flat without sheets between them? I only have a few windows and I left them on the V-birth without sheets in between them for the winter.
Doug
Doug,
There is a possibility of scratching the plastic. Plastic against plastic is abrasive.
Doug
I would be afraid to have the eisenglas touch each other without a sheet or other material separating them. You might get some outgassing of the plasticizer between the eisenglass thus leaving a residue similar to the fog on your windshield in your car.
I've stored mine without anything between, but they were squeakly squeakly clean and not disturbed the whole time they were stored under the mattress.
