electric boats
tcijoe
currently i am not aware of any electric boat that could/would replace my stamas however as a marina cruiser, cocktail cruiser, or taxi service i think these seem pretty neat.
seems to me a bit higher priced then a comparable gas boat with the same hp however there is somthing to be said for the quiet and enviromentally friendly boats.
what does everyone here think of them?
For a short range cocktail or sunset cruiser they'd be hard to beat... Not if you want speed or long range though. A lot of us may not be able to afford the speed and long range much longer, anyway.
I'm in the process of setting up a canoe for electric power (my second); they do quite well with a simple trolling motor and a couple nice seats.
I suspect a small sailboat would be pretty easy to convert to an electric launch.
Glen-L marine has plans for several models, too.
Yep, I looked at 'electric boating' for lakes a long time ago.
I still like the idea.
I had a design (Dream) of using a small gas motor to operate a small Alternator off a Jap car to make an onboard battery charger.
My idea was to have a circuit sample the battery voltage.
If the sample saw lo-volts a number of times, I caused a relay to close which started a sequence of starting the Gas motor and re-charging the batteries.
I know that little Jap Alternator would not re-charge a number of those big 'D' sized batteries right away. There is probably a better idea already in place somewhere.
The Charging system could run for hours un-attended whether you were under way or docked. Soundproofing might be a problem.
You mean a Gas Generator made by Honda, called a 2000, that is an electric start?
Good Idea! See there, somebody is listening to me.
Seriously, Willie's idea would make a pretty practical electric lake boat.
With something that sophisticated you could just walk up n' press the button when you felt the need.
My homespun idea was going to work even if the boat was setting in you back yard. I'd put a set of lights or some such to keep a draw on the batteries.
The Self-starting battery charger would keep the batteries up in the 10% range.
Batteries are getting better, and of course the Charging systems offer more options, and Fuel is going up!
Sure makes those electric boats look a lot more attractive.
The Honda 2000 is not electric start--it only puts out 8 amps 12 volts DC. It will run a battery charger, but do not feel that would be an effective way to power a boat. I once had a 5 HP air cooled engine which was belt driven onto a 50 amp alternator. You had to remove any alternator load to pull start the motor (used for emergency battery charging).
I currently have a 12 foot aluminum skiff with a 53 lb thrust salt water trolling motor with two golf cart batteries. It will run at about 4 knots for 3 hours--at a slower speed considerably longer. It is a wonderful silent way to observe wild life in our bayou. I use a 6 amp battery charger to keep the golf cart batteries topped off.
http://dsehybrid.com/?gclid=CKOtjsrZlZICFRWiQQodOXL66Q
Boy, that one looks great! I could get out into the Atchafalaya Swamp and stay out until I had to see a Doc or some other outside service was necessary.
Admittedly the 2000 is not electric start, but I'm not so lazy I couldn't give it a crank when needed. It may only put out 8 amps at 12v but as you're probably dealing with a 36 or 48 volt system you're going to have to use a 120v charger anyway. 2000 watts is over 50 amps at 36 volts, about 40 amps at 48 volts. I think listening to a noisy Briggs would sorta defeat the purpose...
I checked the Duffy website and they claim 5-6 hrs at top speed... that could be 30 miles or more. Most folks would just wait till they got home and plug it in.
Then there's the Elco Hybrid: http://elcoelectriclaunch.com/hybrid.htm
there is no benefit in using an engine to charge a battery to run the boat. that will use as much fuel as just using the engine and the engine will have to be the same HP as with an engine alone situation. There is no magic the power must come from somewhere however plugging the boat into shore power as with the Duffy is very economical. The speeds will always be limited to displacement levels because of battery size limitations. Only a diesel electric drive could plane a boat for any time but that is just the same old diesels with an electric drive train.
i am doing some preliminary investagations in to the duffy style boats. i think it would be very neat to have tied up behind my house and just run out the canal in to tampa bay for a sunset cruise.
seems to be very reliable as it runs off the same basic principal as my golf cart.
i like the idea of some even having a full enclosure for the cooler days
I've been using Minn Kota electrics to power my dinghy for years: match made in heaven! My Brig 9.5 went over 5knots with a Max50T, or would cruise over an hr at 4 with a small Group 24 battery. True, the range isn't there, but for exploring coves or getting to and from the Marina, they're great! And just hook it onto the engine's alternator or shore-power battery charger and you're good to go again.
In fact, out on small lakes in the interior, I have a Max40T that lets me troll all afternoon. Add a solar panel and it's pretty much good to go again. Or, again use the truck's alternator when you're moving from lake to lake...
druid
My ONLY reason for having an on-board charger was enviromental.
I boated several miles up a lake to camp and hunt. There was no Civilization at the other end of that lake!
The Battery would take me most of the way up the lake but I had to row back. Several miles.
I thought it would be handy to have a little (gas engine)trickle charger to refurbish the battery so I'd have something to come home on when I was done hunting and all tired n' such.
Willie's right about that noisy Briggs too. Anything you dont want in your nice quiet wilderness is a Briggs pounding away.
I wouldnt want that either but it would do the job cheaper than scavenging one of the newer two cycle Weed eater motors with all that smoke and screaming.
Those wind-powered boats will never work.
Thud in your situation I'd think it would be easy enough to carry a second battery for the return trip. But if you must you must... there are lots of sites for building gen-sets from old lawnmowers and edgers. Go for it.
Yzer I'd imagine most of the surviving Native Americans WISH you were right!
Originally posted by pdecat
Thud: sail?????
I had a ride in one of them 'whiffers' once. It was as fast as watching grass grow, and as complex as brain surgery. No thanks!
I helped up-right several of them on a lake we were fishing, while they were holding a 3 Meter regatta.
I want a boat that will keep me dry. Those 'whiffers' demand that you get wet and know how to get into the water to get your boat upright again by yourself.
Can you see my Fishing and Hunting gear all wet?
Willie I carried the second battery. It was the simpelest answer.
In a Rubber inflatable you shouldnt let any battery acid set on the surface very long. A battery cannot be tied down with any old stuff. It has to be acid proof.
There's no simple answer. But the answers are getting simpler....soon enough we'll all be using Hybrids for small boats.
I think you would find sailing better than rowing.
