Electronic solid state bilge switches
BAYCRUSIER
Does anyone have any experience with Solid State Electronic bilge switches.Thinking of replacing the old mechanical one in forward bilge. Good reports ...bad reports Thanks Joe
I put in several in customer boats. Never had any complaints. Even the one in an oily bilge worked fine after 2 years.
Excellent. Won't pump oil should you have spill in bilge however when oil floats above sensors pumping resumes till oil touches contacts again.
I replaced my main bilge switch several years ago, well worth the effort.
Only problem I have experienced is with certain types of bilge cleaners they can leave
a film on the contacts and the pump will stay running.
I installed mine on a rod that is adjustable so I could get the level in the bilge just right.
Also makes it easier to remove to clean if needed.
Abouttime
After losing 2 switches in a grey water sump in 3 years, I installed one. End of problems - 5 years and going strong.
I've had some experience with the Water Witch ones. Similar arrangement, all solid state, haven't seen one fail to operate yet. HAVE seen the plastic boss where it bolts on broken off a few times from getting hit with boots or deck grating. They're what the 47' Motor Lifeboat uses for it's bilge sensors, as well as the trigger for the Emergency Window Release System.
Changed 2 of my 4 out to the solid state type.
No failures yet and no problems.
Will eventually do all of them.
