Electronics HELP!!!
I use laptops on my boat but not for navigation. I use them to stay in touch with the office. I also have a library of every piece of equipment and electronic manuals that I have on the boat. I use it to keep track of my EPIRB registrations, Satphone contact information, Direct TV contact numbers and my maintenance schedule. My wife uses one to surf the net. I would never use a laptop for navigation even with a daylight viewable screen for one reason when they lock up or freeze it can take minutes to bring them back and restarted then reload your navigation program. By then you could be in some deep crap. I have never had my Garmin chartplotters ever drop out or restart. The other problem is power with a laptop you either need a small inverter or a DC converter they are not made for the marine environment. Yes there are a few specialty computers for marine use but they are more expensive than a decent 10" multifunction chartplotter.
david..
i went with the 4208 this year on our trawler. love it.. simple easy to read eas to use...
bob t
32 grand banks
sarasota fl
I just bought a Lowrance and really like it. Wiring was easy and the display quality is top notch (even in direct sunlight) The inland charts seem to be more detailed than what Garmin offers. For coastal / offshore, I think it boils down to personal preference. The biggest piece of advice I received when I posted this question a few months ago was, "go with a name brand and get the biggest display you budget will allow."
David,
The more I read here, the more I think you need one of Lil's, Bloody Mary's to get thru this "electronics" debacle. I just had one and everything is mellow, wish you were here to enjoy one too.
Harlan
I thought of taking a trip to Lake Conroe, Texas. I saw a nice one on a Regal there!!!! ;)
Really, either:
LCX-28C HD COMBO W/ 200 KHZ T/M, LGC-3000 GPS ANT
http://www.boatfix.com/cart2/Scripts/prodView.asp?idproduct=13674
or
LCX-38C HD COMBO W/ DF T/M DUCER AND LGC-3000 GPS
http://www.boatfix.com/cart2/Scripts/prodView.asp?idproduct=13690
I have a Raymarine depthsounder / temp sensor that will do for temp readings and a B/U for the GPS depth. I would truly like to get rid of the Raymarine and use the dash space for something else.
I like the layout of the Lowrance and the fact I can add the 1500 radar at a later date is great.
As I stated, I like the Sitex and if I could find a daylight viewable screen (actually I did, however an 8.4" was about $2200!!! OUCH!) this would not be out of the equation.
SI-TEX Explorer Plus With GPK-10-6 GPS Antenna (EXPLORER PLUS)
http://www.boatfix.com/cart2/Scripts/prodView.asp?idproduct=6384
http://www.si-tex.com/html/explorer_plus.html
Please...Any and all opinions / suggestions welcome.
Really, either:
or
I am not too worried as long as you keep thinking I own a Regal ;-). Either one of those units will work just great but I vote for the LCX-38C if you have the extra scratch. You can also buy that unit without the transducer if you like. Good luck!
We have seen two issues with Lowrance that may or may not be a problem for you:
1) The molded cable ends for the system are large and make it difficult to run thru wire chases and tower legs. Other network systems have this problem also. If you are installing yourself, check the size of the cable ends relative to the places where you will be pulling cables.
2) Lowrance appears to buy equipment from multiple suppliers, therefore components many vary in external dimensions from box to box. We purchased a radar pedestal for a Lowrance that did not match the holes for the antenna. Assuming the supplier of the mount made an error, we called to complain. The mount supplier told us about the multiple suppliers.
LORAN ? what the heck would you want loran for? what did i miss? can we throw in some 8 tracks and maybe a Betamax while we're at it?
Locally, the sport fish charter captains use LORAN. Personally, I think that it is so that they can tell each other where they are catching fish on the VHF without the rest of the world finding them. Seems like a DSC VHF would serve them better,
you want simplicity? GARMIN! the best most user friendly interface and excellent charts.
GARMIN has changed their user interface (UI) on some models recently and I find it more difficult to use than the "old" UI. Still, it is easier to use than the Furuno NavNet VX2.
Saturday, I was on a sea trial with big twin Furunos and C maps i think... what a POS compared to the garmins. takes longer to figure out the menus, couldn't see some bridges ahead to find the clearance... yikes.
I have both a Garmin handheld (GPSMap 478) and a Furuno NavNet VX2. On a recent trip on the ICW, it was actually easier to get bridge height info on the Furuno than the Garmin. Garmin wants to "snap" the cursor to an object, so sometimes, it was difficult to click on the bridge.
C-Map and NAVIONICS both do not display Nav aid numbers. You need to cursor to the nav aid to get the number. Garmin g2 has the marker number on the screen. This makes it easier to transit areas where channels cross and nav aids are far apart.
My first GPS was a Garmin and I found it very easy to use (still do!). My current boat had Furuno on it when I bought it, so I have "learned" it. The Furuno is flush mounted on the helm but I always get out the Garmin when underway. It is nice to have one display showing the current situation while loking at other info on the other unit. The Garmin also has XM Weather, so most of the time, it is zoomed out to show NEXRAD weather radar.
If I had no GPS now, I would purchase a Garmin.
I have a Raymarine C80 with Navionics Gold charts and a 48-mile radome so I can overlay the radar on top of the chart. That is a great feature. I can create routes on my PC and transfer to unit via a memory card. I can also configure a split screen showing the the bottom with sonar. I have a portable hand held Garmin Etrex Legend with Blue Chart for backup not connected to anything in case of lightning or electrical problems.
Bobby Wilson
4207 Carver
Orange Beach, AL
