I need some experienced opinion/comments on this subject. By the way, I broached this problem on the Engines forum but did not get a knowledgeable reply.
My twin Volvo diesel engines have a diagnostic system that according to the user manual will detect faults and blink out a fault code identifying the problem. After one year of no faults, the fault light (orange/red) goes on but I can not get it to respond with an ID code. Most of the faults listed suggest contact dealer/auth. service anyway. Service rep shows up with a regional rep and laptop computer which is plugged into both engines. After consultation with Volvo HQ, proceeds to download and reprogram both engines and helm stations with program from the laptop.
Engines perform perfectly for three months. Then yesterday another fault light shows up. Port engine shows no oil pressure. . . gauge goes up to 5 and then back to zero. . . all other gauges working normally. Starboard engine gauges
all OK. Both heat gauges show normal but after a few minutes I shut both engines down. . . waited a while and restarted. . . same result. Guess I need the guy with the laptop again.
How common is this with these computerized engines?
