I have a '88 Bayliner Saratoga with a 5.0 liter. The boat use to run ok, but now isn't running at all. I changed the points 3 times, put a new condensor and rotor in, new plugs. It's getting great spark, and I can see the fuel, it fires for a second, and then stalls?? I just filled the boat up on Saturday completely and added some fuel additives. The only thing I didn't check is the fuel water seperator filter. I also wanted to see if it would stay running on starting fluid. Does anyone have any suggestions? Also when boat was running before, it ran great without a load, but when I opened it up on the water, it seemed like it wanted to load up and go nowhere, but occasionally would take off running good. Getting frustrated quickly. Someone Please help!! Thanks!!!!!
