>Is the alarm sounding? What temps on the gauge?
Yes, Alarm sounds at 205 on gauge.
Do you have good flow at the inlet hose to the RW pump after it has gone through any upstream coolers? Note, 1/2 normal flow at any given rpm or just cracking the strainer lid still looks like a LOT.
>If you let the pump outlet hose run into a bucket (before it has reached over-temp, is there a lot of air in the stream?
will try this and let you know
>Did you look closely at the housing wear surfaces of the RW pump? If scored there, even with a new impeller you may not have suction to draw >water at low rpm when the impeller vanes must contact that surface.
Examined housing very closely, looked good, impeller looked good.
>When it has elevated temps , again, what is your palm telling you about the riser/elbow tops , and does that change if you increase RPMs?
Riser temps for good engine 0 mins:68, 5 mins:69, 10 mins 89, 15 mins:106
Riser temps for bad engine 0 mins:62, 5 mins:122, 10 mins:303, 15 mins 350
Did not try to increase rpms, but will try and let you know
Is the circ pump pulley turning properly and no sign of leak at the circ pump weep hole?
Yes, belt is tight and pump turning. No leaks.
Thanks,again
