Engine Room Blower Setup
gcolton
Well-known member
I have been having a problem with the engine room blower. Yesterday I crawled into the cramped spaces to determine just where the blower motor was located.
In doing so I saw that the inlet and outlet were 4" collapsible vent pipe like what would be used in a dryer. The blower motor was in the middle (actually near one end) of this piping. Not that it matters for this discussion, but the blower is a cheap looking DelMar.
What I did not understand was that the piping for inlet war run to near the forward end of the port ending and the outlet was near the forward end of the starboard engine. The blower is mounted so that it sucks and blows out the starboard side.
It seems to me that this configuration does not do much to provide air circulation/venting for the aft part of the engine compartment. This aft part is where the generator is mounted.
I think that the inlet pipe should be at the very back of the engine compartment on the port side.
Does this concept make sense to anyone else?
G
the blower should be set up to remove air from the bottom of your engine compartment. gas fumes will settle down to the lowest point. if you are pushing air out with the blower, the make up air that comes in will generally come in from above and be cooler. it works by passing cooler air down thru the hot air that rises to the top of the engine room. the gen set will generally use enough fresh air to supply it with enough cool air to keep the power head cool. from a noise perspective, the blower motor will push air more efficiently than pull it, so if you configure the motor with as short an intake line as possible, you will push more air thru the system.
as far as the proximity to the generator goes, don't worry about it. hot air rises and you'll never move air thru the engine room at a speed fast enough to over come that so it will be cooled by the air exhange provided by the blower. you can limit the amount of heat radiated into the engine room by installing a generator sound shield. this will also cut down the amount of noise it makes.
Vic, my concern is removing unwanted/potentially dangerous fumes from the engine compartment. I am especially concerned about fumes that may accumulate around the generator since the blower system does not cover that part of the engine room. I have no concern about cooling the generator. This should be accomplished by the generator cooling system.
As far as I know the engine room blower is not configured for this function. The blower's primary function is to remove funes. I am just concerned that the placement of the intake and exhaust pipes will not properly accomplish this function.
G
"the piping for inlet war run to near the forward end of the port ending and the outlet was near the forward end of the starboard engine. The blower is mounted so that it sucks and blows out the starboard side."
i dont' really understand your description. the inlet hose going to the blower should be low in the bilge. The outlet hose should be routed to the outside, usually being the ER vent covers, louvers, whatever your boat uses. Wehn the blower is on, it sucks air from teh bottom and blows it out.
You raise a good point though... in a twin engine + generator boat, chances are that you have some tall stringers. If the blower intake is in the central bilge, fumes (lower than air) could accumulate in another area (near a generator) and not be vented...
interesting theory... would it be worth adding a second blower in such a set up to pull fumes close to/under the genny area? maybe...
G
without seeing detailed pictures of your engine room layout its hard to help you here.
just FYI, if the generator is allowing any fumes at all to accumulate in the engine room you need to fix that problem, not evacuate them with a blower. the blowers only function is as a back up safety device in case something else fails and deposits fumes there.
Pascal, I see your problem with my description. The intake hose/pipe (a 4" wire ring with plastic covering like a dryer vent) runs several feet from the outside intake port to approximately the front of the port ENGINE. The exhaust is on the starboard side with the blower inline. Both "hoses" are at the level of the bottom of the engines and neither is at the lowest part of the engine room. The position of neither generates any air circulation in the aft part of the engine room.
It would be very difficult to take a meaningful picture.
Vic, I think that you are being concerned with exhaust fumes or the like. To me the engine room blower's main function is to vent any potential FUEL OR OTHER SIMILAR dangerous fumes. I am not concerned about exhause fumes or heat. I am trying to evacuate any fumes that might cause an explosion at startup. Of course I always stick my head into the engine room and do my own sniff test before I start anything.
I am thinking that I might replace the end of the intake hose so that it is in the rear of the engine room on the port side. I think that this should provide better air circulation. Comments?
G
yes, the purpose of the blowers is to eliminate fumes that could accumulate in cas of a fuel leak. it is the back up/safety system but as such it must be effective.
so if get this right, air is sucked in the blower hose at the front of the port engine. the hose goes back and across to the blower and then outside. It's the mention of the "exhaust being on the starboard side" that confuses me... the outlet side of the blower is connected to a hose that exits outside of the ER,right behing the vent/louvers, right?
depending on the bilge configuration, i'd consider adding a blower aft by the genny in case stringers would prevent fume near the genny to get to the front.
and I woudn't own a gas powered boat without a fume detector!! the sniff test is good but if a leak starts while the genny or engines are running, you're not going to smell it.
The blower also exhausts heat build-up with-in the engine compartment. Nothing wrong adding another exhaust blower. The other side of the exhaust blower system is the fresh air intake system. This intake must also supply enuff air to feed the engine. The fresh air intake line hose shouldn't be near the intake of the exhaust hose. Exhaust hose should be at lowest part of engine room(as noted)
There are actually regs that cover ventilation. Here is a short quote from the boat builders handbook, that includes the regs involved:
Powered Ventilation
FEDERAL LAW
183.610 - Powered ventilation system
(d) Each intake duct for an exhaust blower must be in the lower one-third of the compartment and above the normal level of accumulated bilge water.
The purpose of exhausting air is to remove potentially explosive or flammable vapors that accumulate in the engine compartment during normal operation of the boat. It is intended that the ventilation required by this regulation be sufficient to maintain safe operating conditions under normal circumstances. Ventilation cannot be relied upon to remove liquid fuel or all of the vapors that may be present if there is a leak in the fuel system.
It is important to evaluate each engine compartment design and locate the intake opening of the exhaust blower duct so it will be in the best position to remove any collected vapors.
The vapors that occur during normal operation are associated with carburetor boil-off after the engine is turned off. These vapors will flow to and collect in the lowest part of the compartment. The duct connected to the intake side of the blower is used to select the point in a compartment where the compartment air will be exhausted. The regulation requires that the exhaust blower duct opening be located in the lower one-third of the compartment. Refer to 183.630(b). Usual locations include:
* under an engine
* between engine stringers
* at a sump, possibly provided as a bilge water collecting point.
Consideration must be given to the possibility of normal bilge water accumulations covering the intake opening. Normal accumulations of bilge water occur from propeller shaft stuffing box seepage, spray while operating the boat, and rainwater. Water remaining in the boat after a bilge pump completes its normal pumping cycle would be considered normal. The opening of the exhaust blower intake duct must be above this normal level of accumulated bilge water.
The lower end of the ducts should be securely fastened to ensure the system’s continued operation as intended. Normal operation of the boat or routine maintenance on the engine may result in the duct being removed from its intended pickup point.
