I am told that all vessels going to Isla Mujeres have to have customs clearance from the US. Here is the form you need:
http://www.nwcaribbean.net/picasso.htm That must be stamped by your local customs office at the port of departure. I am told that the Port Captain at Isla Mujeres is fining any vessel without this. I know, you don't need clearance to leave the US.
That does sound steep--and I have always done my own clearance in Mexico. Customs, the port captain, imigration and the bank are all close in Isla. I would have 6 copies of the crew list in Spanish, be sure that every person has a passport. Here is one experience a couple of years ago:
http://www.nwcaribbean.net/picasso.htm This is far more complex than what we experienced, but we had checked into Mexico initially in La Paz on the Baja Peninsula. Also this time of the year there are two sailing races to Isla--so besure that you can get a dock and fuel, if you require this. I always have multiple copies of the ships document papers, each member's passports and crew lists. We carried a scanner and computer, with printer. Plus had the various forms in spanish on the computer so it was fill in the blanks.
You should be able to get an "in transit" permit and avoid the import duty, the fishing licenses etc. Assuming that your final destination is not in Mexican waters. We have done this several times when only doing a delivary and stopping at only one port for fuel. This saves a lot of hassel--but then you cannot anchor or explor other areas. I also hear that you cannot anchor at Isla Controy before check in any more. Also you need a permit to visit there after checking out of Isla Mujeres.
Also unless you are the owner of the vessel, have a notorized power of attorney over the vessel.
