Excavator (sp?)
ckw
If one fell off a Dredge Barge, how would you get it back out of the water?
It's 60-70' down now.
I would think that a barge with a crane would do the trick...Did one fall off somewhere?...
It depends really. It may end up being left where it is and create a great dive site. (Happened here with a crane a few years back)
I am no expert, but my guess would be lifting it (in whole or pieces) with air bags and using a crane to get it on another barge.
Well, acording to my neighbor, after I asked why the FD, and all the Cops, were blocking off part of the main channel, here is what happend.
The were pushing the barge with the equipment on it.
The front of the barge went under, the operator of the Exevator was in the cab and moved in backwards on the barge.
It went over the side.
He's OK, and came to the surface.
Operator said he saw, on his way up, the machine turn upside down.
It's in 60-70' of water, but has an 80' boom.
Now the booom is not straight out, but, that chunk of steel went down fast.
With the weight, it had to bury into the bottom pretty good.
Environmental liability. They can't just shrug it off. At the least, they'll have to mitigate pollutants, if not remove the entire apparatus.
But as far as the question of raising it, would be better to hoist it. It'll be a heavy load, and a sonofagun to keep balanced if lifted by blowing bags on it.
Well, the enviro. problem, is a real problem.
They said "The fuel is not leaking", but it will.
How do you get the boom down?
Cut the hydrolic (sp) lines?
That's going to cause a spill.
This is an inland lake.
What went down is the biggest machine on the Lake.
If there are enough bags to float, maybe they can get close enough to a boat ramp to get a Crane to lift it, but it's going to be a long way from shore.
I'm thinking they need to get the boom down, and leave it.
Maybe they can get it out, but it's going to take alot of equipment from the Coastal regions.
Just saw one of those shows on The History Channel about those scrap salvage operations that recover drilling rigs, etc, after storms etc, that are 200'+ down. I would think this would be a fairly standard salvage operation, albeit difficult as most are.
Ya, but I'm talking Lake Norman NC.
A land locked lake.
We are a long way from the coast, where they have that ability.
It would take 6000 years to get Goverment permits to bring that kind of equipment across the road systems in the United States.
Having built several docks, I dropped altot of tools.
They are gone.
You cannot see over 4 feet under water, on the best of days.
Came back from a trip to the Caribian, after spending alot of time in the H20, and thought...........I'm going to get everything back that I dropped, It's only 12-15'.
Wrong.
Our divers are of the rescue type, not salvage.
That's alot of unstable weight.
Put the float bags on it, and, who knows what's going to happen.
Sometimes you need to let speeping dogs lie, but with our Gov. out of control, it's not going to happen.
I would expect attaching/inflating an approriate size & number of commercial lift bags and the use of a lighter barge and possible need to tow to shallow waters for final removal would do it.
..Or there's always the Glomar Explorer if that's still around.
On Mother's Day at least 10 yrs ago I was next door at the folk's house looking out at Vineyard Sound and noticed a familiar dock-building barge with built-in crane and it's tow boat stopped about 1/3 nm away. Got put the telescope and saw the crane cable straight down over the side and a diver slipped into the water . I was amazed to see a very large pod of dolphins slowly cruise right over the divers bubbles and amble on -never saw them in that area before or since. A bit later the diver surfaced and a steel bucket came up via the crane. Eventually with the help of a 2nd barge & mobile crane onboard, the rest of the very large Bobcat was lifted back onto the barge .
Since I know the owner of all of the above except the bonus dolphins, I asked him about it a couple days later. He said the towed unmanned barge with Bobcat had taken on water due to a faulty pump and sea action and developed a quick list , dumping the Bobcat the day before.
When he retrieved the machine from about about 50' depth he rinsed the machine's externals with FW, changed the oil , started it up and it's been working just fine ever since.
