Expected generator maintenance
WaxedElvis
I'm considering a new twin outboard boat with a generator installed (Westerbeke) and I've never had a boat with a generator before. What are the normal/general maintenance expectations? I fish in saltwater so would flush the outboards after each trip (I do this on my current boat). Does the generator need to be flushed as well? If so, what is the process, how is that done?
Thanks in advance.
My procedure for maintenance is something I developed which may or may not be part of the westerbeke manual. If I start the generator I make sure it runs at or above 75% load for at least 15 minutes each time (I turn on the electric stove to almost high on every burner). This will allow the generator to completely warm up. Dries out the generator portion and dries out the engine crankcase condensation. I then let it run for at least 5 minutes with no load before shutdown (allows the generator section to cool down). I have a Perko flushing valve that is in line just after the strainer. Normally you would hook up a garden hose to it. The hose pressure shuts a valve on the sea side and the hose water flushes the engine for about 2 minutes. I do not need a hose as I have it permanently plumbed into my onboard water thru a valve. I am just careful to close the valve as I shut down the engine so saltwater does not have a chance to enter back in and so that I do not have water pressure when the engine is not running.
I've always been told that the best thing to do for a genset is to use it under a load & often. Your genset is most likely FWC (closed cooled), so saltwater only enters the heat exchanger and exhaust. It's probably a great idea to flush the cooling system with fresh water after you use it but that would probably limit my generator use. Not much routine maintenance, check coolant, change impeller and change the oil and filter every 200 hrs or yearly.
Most gennys will also have a zink that will need to be changed on a regular basis. Find out where it is and check it often, you would be surprised at how quickly they can deteriorate. I also run my genny for at least 20 min to an hour each trip to keep it fresh and running properly. The worst thing you can do is not run it!
I am not sure if there is a significant difference between my home standb y generator and a marine generator. My home unit is factory set to run for 12 minutes every week. This is not under load. It is natural gas powered.
Why would a marine generator need to run longer than this and why would it need to run under load?
Just looking to get educated here.
G
IMuneducatedO
The engine part of the generator
Gas - no load necessary
Diesel - load necessary to bring engine to oper. temp and to prevent "load up" of carbon
The electrical part
Load needed to generate heat to disapate moisture and discourage corrosion (work relays etc.)
I'm a Generac Generators dealer. We don't sell marine generators, but running under load is mostly required in diesel generators. For diesel engine driven generator sets running without a load can cause ‘wet stacking’. Wet stacking is when unburned fuel accumulates in the engine exhaust. This is caused by under loading a generator. When exercising a generator, or running it for short durations while under loaded, or with no load, the engine may not reach its optimum operating temperature. When this is allowed to continue for long periods of time the unburned fuel accumulates, and can become harmful to the engines efficiency and life span.
This also applies a little to gasoline powered generators, though not as important as it is to diesels. Any load is probably enough with a gasoline generator to keep condensation out of the alternator windings, and to keep corrosion off the brushes.
The home or business stand by natural gas or propane generator burns a very clean fuel, so there is virtually no unburned fuel deposits in the engine. Testing without a load is just fine, mostly designed to keep oil on the bearing surfaces. Remember the harsh operating condition of a standby generator, it starts from cold, immediately goes to 3600 RPM, then has a big load dumped on it, all within seconds. Thats why we like to see the weekly "running" to keep the oil on the parts that need it most.
