Extended Swim Platform
carver 2557
I have been in touch with swimplatforms.com and am considering extending my swim platform with one of there models...I have not heard any bad comments about their quality of work...
I would like to go as big as I can without making the boat look like crap...What would the suggested maximum length be to add on?...Do these extensions drag in the water when coming on plane?...My LOA is 30 feet...
I find the small existing platform to be somewhat usless...
Here is a boat pic...
Having been on your boat Wayne I'd think adding 2-1/2' would be just about right. Anything more than that would look like an aberration! ;-)
What I might do before ordering is to cut a piece of styrofoam, set it on the existing platform, and see what it would look like...
Cheaper to do that than to order and not like it when it gets here...Styrofoam is cheap...Platforms are not...
The beaver tail look is in, so I'd add about a 6 footer back there. Then get a smart car and park it there. :-D
I agree that 2 1/2 would look just about right, even 3 feet may not be too big.
Shel
3 extra feet is what I was wishing for...I'll try the styrofoam 3 footer, and maybe Rick can drop over and have a look and I can get his opinion...If it looks too big, I can just cut the styrofoam until it looks good...He seems pretty sharp...What did I just say?...Are you going for the brunch this weekend Rick?...
Maybe they can build a custom platform that looks like a beaver tail...EH...
I looked at a similar set up with my 1999 Chap 240. I called the factory and they recommended against it due to the extra strain it would put on the transom with out any reinforcement. I would take into consideration the overall size and how much weight you could possibly put on the platform and then look at the support system and determine if they are all mutually supporting. If it’s too big, and you swamp the platform, take into consideration the weight of the water – even for a few seconds, and the effect that will/could have on the transom.
Just some things to consider….
Wayne,
I have a Swimplatform.com on a 25 ft. Sundancer. The fit and finish is great and look like a factory job. I would ask them for their advise on the size and do what they suggest. These guys who own the company have years of combined experience in the boat building business. my .02
Harlan
They usually have a form built for popular boats. If they have not built one for your boat, it might take longer for them to put it together. I agree and think they would not steer you the wrong direction. Getting 3 feet added, MIGHT be ok and would depend on how high above the water it sits, stresses and the load on the transom. I'm sure they have all that factored in. I boated with a couple of mid 90's Sea Ray's that had their extensions and they were first rate in appearance, how they blended in with the lines of the boat and added a ton of extra room on the back. I'm considering one as well.
Another
www.swim-platform.com
Good experience with them and couldn't imagine not having one now regardless of where it came from. Great fit and finish (non slip) Added 2 feet, the built in Euro was too little to be very useful and just enough to make falling off all too easy...Don't worry about hitting the props any more.
No problems with dragging coming on plane and no problem supporting several of us standing on it. Have two support brackets. Weighs 36 pounds.
Posting from the hospital...hate getting old. Wayne...if you want any more info, feel free to e-mail
Stan
3 EXTRA feet is not a small amount. Proceed with caution and common sense as Jim(lakesponge) suggested. Using existing attachments may prove to be inadequate do to increased leverage and the probability that a larger swim platform will invite increased loads.
I put a swimplatforms.com "deck" on my 305SB at the beginning of this season. Best thing I ever did. The molded in platform was about 2 feet deep and the extended platform is about 4 feet deep, with 2 of those feet overlapping the molded in platform completely. The installation looks very good and we've had no issues with weight or dragging coming up on plane. We've had several adults on the platform at the same time with no sense of give or stress. I now carry my dinghy (inflated and laying flat instead of on its side) back there when underway (instead of on the foredeck) and still have no issue getting on plane.
I also added an extended swim platform on our boat this year. It did make the boat feel a lot bigger. I chose to have my local fiberglass shop custom build one. It came out great, matches the transom curve perfectly, and is larger than swim platforms.com makes. I had it make 3 feet long. It does not look too long for the boat, it looks great.
It sits about 1.5 feet above the water, so no issues with it getting swamped. They bolted it along the transom and used four angled supports, it is very sturdy. They removed the tow eye and hand grab for the old ladder and mounted it a bit higher that swimplatforms.com does. Just below the rub rail.
Cost wise- the mail ordered one was almost 2000 bucks delivered, and you have to install it. I paid just about the same price, got a larger one, and had it installed.
James
I was thinking of checking out the same thing as James and have a local fiberglass guy give me a quote for a customer extended swim platform. I've checked out the aftermarket ones mentioned above and for my model (Wellcraft martinique) it looks nice but it ends up being a step down from the current swim platform so it definately looks after market. Anyone else have experience with custom fabrication, pro's & con's?
The styrofoam is a good idea. Helps you visualize. I'm not as think as smart I am! Duh! I only gots a grade six edumaction! ;-)
You would be amazed at how well the swimplatforms.com platform is. I purchased one for my '99 Crownline 225ccr and it was better built and better supported than the factory one that came on my '03 Crownline 262cr!
Scott (the owner) used to work at SeaRay, in what function I'm not sure. But he knows how to build a quality unit and he knows customer service! Very helpful!
I finally added an extended swim platform from swimplatforms.com this year and I'm amazed at the quality. In my opinion, it's way better than the OEM platform from Regal and it looks great on the boat. It really does make the boat seem a LOT bigger now with the platform. I had my local marina install it for me and it took 2 guys about a half a day to put it on. I only wish I had done this 5 years ago! The guys at swimplatforms.com are great to deal with. You can't go wrong buying from them.
Here are some pics of my boat with the new platform from swimplatforms.com.
That's really nice Jeremy. The proportions are right on! Very nice addition to your boat. We saw a boat this summer, similar size to yours with a swim platform about 6 or 7 feet off the transom, it looked really odd.
Jeremy:
Very nice...How much larger did you go on your platform?...
