Exterior Carpet ??
Moderator
Need a heads up on this company.
WWW.Snapincarpet.com
Price looks good, samples sent look good, anyone ever deal with them?
The carpet I am looking at has that new backing, not the traditional rubber.
What sucks is my existing carpet is good, but the rubber backing is falling apart.
Are you talking about Custom Marine Carpet whose web address is www.snapincarpet.com? If so they are making new carpet for my 1986 Silverton as we speak.
Yes I am,
Did you send them your old carpet to use as a template? If so, are you having them install the snaps?
I had the original carpet on the bridge and no carpet in the cockpit. The bridge carpet was so old and rotten that I decided to make paper templates instead. I bought the contractors paper at Lowe's and made templates of the bridge and the cockpit. They suggest installing the snaps locally if you already have snaps in your boat, which I did on the bridge.
i had them do cockpit carpeting a few seasons ago for my vista. i sent them the old carpet, which was falling apart and had them make me a new one with snaps. the carpet is great. my only complaint is that one or two of the snaps are tough because i have to stretch the carpet a bit. my original was missing a few snaps so that may be the reason. really pleasant company to do business with.
Walter,
I had the same problem you have - good carpting, but the backing was breaking down and sticking to the cockpit floor. I solved this by covering the back of the carpeting with a thing layer of canvas (used a dropcloth from Home Depot). I attached the backing using 3M spray adhesive.
Thought I would have a problem with the carpeting moving around but the snaps always held it in place even with the canvas backing.
Carpet no longer sticks to the floor and I got a couple of more years out of the carpeting.
Walter i havnt dealt with them but i do buy from R$R textiles. they have the better backing that dosent stick to your deck. i saw this backing also at the snapin website above this is the good stuff
this backing shown below will stick do the deck
