I have a 2001 2400 SCR with carbed 5.0 Merc. I started getting hi temp readings in June, I took out Thermostat, later replaced temp sending unit and temp alarm sending unit (opposite side of temp unit). Last season had new impellers and water pump changed.
My oil pressure is good, temp is usually around 175 (before would rise upto 220+), but after getting upto speed for 10-15 minutes, the alarm sounds, pull back throttle and it goes off after a minute or two. I can then get back upto speed for another 10 minutes or so.
Is there another "alarm aspect" I am missing? Is it possible the actually alarm is no good? Is there a rev limiter or RPM alarm? I never have motor above 4200 RPMs. Any ideas???
One last thing, I noticed this weekend that my prop has slight inward bend, could this cause an alarm to go off by itself???
