Fiberglass Yellowing
Robski97
Any thoughts on why my topside fiberglass would start to turn yellow?? Its only around the area where the non skid meets the regular glass..
This can be corrected by removing all the wax and UV damage of the gelcoat. Keeping the fiberglass better protected with frequent waxing and buffing can prevent this. Storing your boat in a covered slip or dry storage unit will help also. The sun's UV damage is the culprit!
Here's a good place to start: http://www.boatered.com/forum/topic.asp?TOPIC_ID=94037
The wax is probably what is yellowing.
What are you using?
Jonathan
Boats gets washed weekly and waxed monthly.... Ill have to find out the wax..
If it was the wax wouldnt it be everywhere ? not just around the non skid areas?...
The transom, hardtop, arch are all perfect... well except for another void that popped up.
Thanx guys
Maybe they are using a certain cleaner for the nonskid that is affecting the gelcote???
Waxing monthly seems like overkill to me.
Jonathan
I agree...it is all about the shine. My 20 year old Carver shines like it's new. I wax every 3 to 4 weeks
Just a thougth Rob. Are they buffing out your gel coat with the electri buffer??
It is hard to tell what is causing the yellowing without a close examination. Often times, excess catylyst will cause some yellowing, sometimes it is pollen staining, somtimes it is wax buildup. I washed my SeaRay with one of those electric pressure washers (1850 psi) that you get at Home Depot. I would not use one of those gas units or a 3000 psi unit because it would damage your gel coat. At any rate, it stripped all the wax off nicely and got the non skid super clean especially the embedded pollen. I rewaxed it and it looks super white. Try that first.
There are special waxes made the for the "non-skid" surfaces. Available on Boat-Fix and West Marine.
TJ
Rob,
Contact Sea Ray its a problem with the mold release agent.
Its a all too common problem, my 36 had it my 42 has it.
Everything from Meritt Island seems to have this problem.
Waxing and cleaning will not help.
I intend to agrue this over the winter.
Lets see how it goes for both of us.
Jim Conroy
2004 420 DA
Buddy of mine has the same problem, Jim is correct about the mold release agent.
Man oh man... Im trying to get some stuff fixed out of warrty already and as I wait to hear from them more stuff comes to life...
Jim,
Do u havea ladder into ur ER bilge ? My ladder is sitting on a fuel line for support. Im waiting for searay to tell me there fix for this as well...
Fun fun.. thanx guys ..
You took that very well Rob. (I'm disappointed) :)
When you mention "mold release agent" are you referrng to the "wax" that Sea Ray uses on the inside of the mold? I know my dealer uses that very same stuff (they get it directly from Sea Ray) to buff out boats after doing fiberglass repairs and this is the first time I have heard of a problem with it.
Rob, DS,
Not sure if its wax or what but I know it seems to be the problem.
Rob, you have a longer hull warranty than the one year stem to stern, register to complaint both with your dealer and copy Sea Ray Customer Service on everything.
IMHO Sea Ray will make this good, not sure how or when.......
No, my ladder sits on the bottom. Not sure how your ladder is attached or how you fuel lines are run.
My ladder attaches at the top and is well clear of any fuel lines. The Racor's are mounted off to the sides.
No fuel line is even close to the ladder.
I'd bet our huls are identical, so I am puzzeled as to what is going on with your boat.
2004 420DA
Rob,
I do not have an anchor (anymore) so I can not PM you.
But if you PM me we can discuss your issues.
I am not affiliated with Sea Ray or any dealer, but I have been to the plants I have met many of the customer service guys and workers, consider some to be friends and consider the service manager at my dealer to be a friend and I am friends with the president of one of the largest Sea Ray dealers.
All I can do is tell you my experiences and steer you in the right direction.
My 420 was not new to me, and it has many issues (I think it was built the day before summer shut down). I am convinced that Sea Ray will make evrything right over the winter.
Now I just wish I was as confident about Raymarine. I am really ticked off that I have to have my course computer rebuilt and that it was a year old when it was installed 'new'.
Jim Conroy
2004 420DA
Rob, if you happen to be at WH this weekend, I would like to take a look. I also have used a guy who was the fiber glass manager for SS3 form many many years. Now on his own. He also may have some insight.
Brad
