fix doc tie up
regalal
hello all i need a little help i will be at alpine basin in NJ this year all they have is fixed docks. can i get some suggestion on how to tie the boat up to keep it from knocking around in the stall.
AL
Cross the stern lines, port line running to starboard cleat/piling, starboard line running to port cleat/piling, with a little slack to allow tidal change.
Regular bow line setup, running to cleat/piling on same side, with enough slack to allow tidal change.
Spring lines to keep you from moving too far into the slip. In other words, assuming you're backed in, take lines from the pilings near the bow, and run them back to the mid-ship cleat. Again, with a little slack if necessary.
Have enough slack in the lines to allow the boat to move with the tide, but not so much that the boat can hit the dock or go under the dock if the water level drops that far. Adjust them as needed, may take a few tries to get it right.
if your slip is wide enough, you can set the lines as Joe said to make sure that the boat never contacts the dock or pilings, often making fenders unnecessary. after a little while, you'll be surprised how precisely you can set how close the boat can get to the pilings or docks without hitting.
if you're using triple strand lines, keep in mind they stretch more than braided.
you didn't say what size boat you have but except for small boats which can easily be pulled against the wind, you're better off using the loops on the dock/pilings and the bitter end on the boat. this allows you to work the line against the cleat and not risk getting your fingers caught in the loop and the cleat... i use nylon ties to mark where i tie the line...
finally, spend a little time after you secure the boat the firs time to see how the lines work. pull on them, even using the engines to see how far the boat can move around the slip. if possible, come back at the next low and high tides to see how it works.
