Fixing headliner
Veg
Well-known member
A Tiara I'm considering has a portion of headliner that's loose, I'm not sure why or how the damage happened. Anyone familiar with how Tiara did it in the late nineties and how expensive or hard it is to fix?
There's no apparent evidence of water leaks, but I do wonder...
Had the same problem on my Regal. The fellow cut a small slit in the headliner and stuck, hard to describe, what looked to be a small wand from a car wash. Fired up his air compressor and shot a bunch of glue in the area and as poked as far around as possible until the wand met resistance. Pushed it in place with a bakers roller and I never had a problem again.
Examining the pic, it appears that the headliner pulled away from the horizontal strip. I suspect if you remove this strip, you will find how the head liner is attached and may be able to re-attach it. I would contact the Manufacturer technical service for instructions, but the fix at least appears fairly straightforward.
Pic? What pic? Must be photobucket which is blocked at work. Sorry Ernesto. I shall check at home.
Ernesto, If there is a dealer near you ask the service guy how it is suspended. My boat is a 2004 and is held up there with velcro. Mine has the same plastic strip and I've pulled mine down by the head to run a wire for the satillite radio. Putting it back was straightforward. I don't think you should shoot glue up there. These things are designed to be removable for doing maintenance (like rebedding hatches, etc.) Also, the factory is very accessible if you go to the website for a phone number they will speak with you. They have a place on the site to ask technical questions as well. Good luck with your search. What model are you considering?
Thanks for the feedback.
sbw1 - This one's a 3100. I think that's the direction we're going...
If the glue application was done properly at the factory and the headliner pad or the frame hasn't come unattached, I would suspect smoke. Headliners tend to become loose if people smoke around them.
Doug
You probably know the 3100 is Tiara's most popular hull ever. It has a cult like following. There are two issues to consider. There was hull design change after the initial design was introduced. I believe the first design was considered a pretty wet ride. It was not a bad ride, just wet. The second design is preferred. And, there was a fuel tank corrosion issue that was discovered after several year's use. Tiara tried to track down every boat and repair the problem. I think they got most of them or at least accounted for all of the problem tanks. You should check both issues so you know what you are buying. Again, the factory can tell you if they repaired the tank of this boat if it had the problem.
sbw1,
Do you remember what model years involved the fuel tank issue?
sbw1 - Thanks for the imput. Yes, I've immersed myself in researching this boat, to the point that it's just crazy. I know of the two hull designs, and actually recently learned from Tiara that they overlapped in production for a few years, but you can tell by the HIN number. Now, I know
Originally posted by reinbilt
sbw1,
I'm sorry. No, I don't know. However, the factory will answer your question. This is a great company with which to deal. Once you own a Tiara, they will stay in touch with you forever.
