Flare Gun
ddurand
I have a 10 year old flare gun that takes shells much smaller in diameter than the 12 gauge ones I see in the stores. Do they make shells for the one I have? I am guessing its 10 years old, but not sure. I have the required 3 hand held flares also.
I am curious to the answer to this one. I have the same gun, I believe.
I have to look at my gun.
I know the flares are all out dated and I need new ones.
Do you have to have handheld flares in addition to the gun?
I thought you just had to have 1 signal device.
Anyone figured out how to dispose of outdated flares?
Called local PD...they can't help. Called county PD...they have no idea.
Called NJ State Police...they haven't a clue.
Stopped at the Marine Police office (happens to be at our marina). They have no answer.
I've got 20+ years of 12 ga flares in a big metal box and don't know what to do with them.
I've heard there are Marine PD or USCG organized "practice" events, but never actually found one.
Stan
In the PNW there is a disposal program through the USCG. You might contact the local CG. Then check with fire departments. Many country environmental services have hazardous waste disposal sites.
There was a "sky blazer" flare which had a separte smaller launcher about 8 mm--and I think Orian purchased this company eventually and modified the flares. I would want the largest flares available, and when offshore we carried 25 MM Solas flares, including parachute flares ($$$) The smaller aerial flares, and hand held flares are not often visiable at any distance during the day (much better at night), and the duration of aerial units is fairly brief.
For daytime, consider smoke flares, and for night strobe or lasser lights, as well as the cG approved pyrotechnics.
You are required by law to have current "flares: If pyrotechnic devices are selected a minimum of three are required. That is, three signals for day use and three signals for night. Some pyrotechnic signals meet both day and night use requirements." The signal device will say approved day/night or one or the other.
I thought the newer shell flares never changed dia. size, but were made slightly longer for help in distance etc. You may be thinking of the ones that used to look like shotgun shells, and the new are the same just an extension on the distal end. The CG is across from us here and I drop all flares to them, and they hold them for when the CG Aux. has a training there. I have shot my 12ga. but have a new 25, but not tried. Just not the thing you give for a whirl, to see how it works.
I went to our local fire department and they said they would take them.
I'd keep the outdated flares and use them in an emergency once the current flares were used up unless storage is a problem.
Yesterday was our 24th of may Holiday and I shot off 9 old flares during the fireworks on the beach, three were duds in that they fired but failed to light.
Use the old ones first, not the new ones in an emergency. You "know" the newer ones would work, better to use them when you have the best chance of being seen. If you save the old ones for last, they may not work when you need them most.
Ken
I was just reading some stuff about NJ regs on the official NJ website and it says that expired pyrotechnic devices may not be carried on board. Don't believe that. Not for a minute.
If you've never fired a flare, at least shoot an expired one down into the water to get a feel for the gun and its operation.
ddurand, by "smaller" do you mean shorter? The newer 12 gauge flares have a considerably longer hull than the ones of ten years ago.
Do the current make 12 ga flares still fit and work in a 12 ga shotgun?
Are you sure the new flares do not fit your gun? I bought new shells for mine this spring and noticed the difference between the new and the old, but the guy at the marina store showed me that they still fit (and work). Just a different shape.
Pistol projected flares are either 12 gauge or 25mm. Both sizes are available. Meteor flares 12 or 25) are shorter while parachute flares (25 only)stick out beyond the barrel length.
Expired flares will be accepted by most USCG and USCGAUX units. They are utilized for training purposes.
Gene
Are the military style 26.5mm flare pistols legal or are they considered a firearm?
I have seen the 26.5 flare guns in some natuical "antique" shops. I don't think that they are a AOW firearm category. They alone do not fire any recognized ammunition. Now if you make a 12 guage shot gun cartage adaptor, this flare gun becomes a AOW weapon--and has to be transfered by a firearms dealer, along with a transfer fee. Shot gun cartages should not be fired in a flare gun--and the 25 mm 12 mm insert are shorter than the 12 guage shells, thus not making them an AOW firearm.
