Flexiteek
HarlenW
My wife wants to have this material installed on parts of our boat deck. Does anyone have any experience with it either personally or through friends or acquaintances?
http://www.flexiteek.com/
Thanks.
Great stuff and wish I had it on my boat but its VERY expensive. I think I was quoted $35/sq. ft. just for the material.
yep... looks really good but be ready for sticker shock unless you're talking a small area.
at $35.00 rb2@gr5t foot for materials, i'm betting its cheaper than teak over the life of the product. refinishing costs are significant.
Thats the same stuff that TT Marine uses. Looks like a good product. I was thinking about the teal and holy flooring for my cabin sole.
I had a quote for about 8K for my swim platform, cockpit, and bridge steps (plus the 'vig' to my marina on top of that). Would have been beautiful, but in the end too many other priorities for me to justify it at this point. I saw them machine a sample, came out really nice. Apparently very labor intensive to 'weld' the sections together to create the borders, etc. Plus it is apparently manufactured in Sweden, so you have exchange rate issues, petroleum based product costs, etc. I understand heat retention can be a problem in some areas with the black seam, less so with white. I agree with those who say it is not really comparable to the real thing, but it still looks great in its own right. The fact that it is a permanent install also was a concern. I also suspect you wouldn't get much of your investment back on resale.
Good luck on your decision.
Vic
Just installed Flexiteek today on my father in laws 24' Wellcraft. Very easy to work with, We made a template ourselves out of cardboard and sent it in. the flooring came about a week and a half after being ordered. cut exactly to size!the flooring is glued down with 3m adhesive (inclueded. took about 30 minutes to install. after installation, we layed down some plywood boards to weigh it down. this was the first time we have ever used this product or done something like this. Very expensive though. $1650 for the flooring and glue for the wellcraft walkaround.
good luck
Gets very hot to walk on barefoot in sunshine or warm climates... other than that, great product...
Whew, $90 per square foot at a local installer. That is sticker shock.
I am also checking out Tek-Dek. Practical Sailor magazine had a review of both products and preferred Tek-Dek which also has double the warranty - 10 years vs. 5 for Flexiteek. They also had Tek-Dek cheaper by about 40% per square foot, and easier to DIY.
I have a small roll of Plasteak with no plans for it, how much do you need,,,etc?
Hkfeen at aol dot com
Fred
HarlenW....You need to be careful about where this product is used. Several guys at my marina have it.
When it comes time to re-finish, they tell me that it needs to be sanded and washed down with copious amounts of fresh water. During this process, sanding of the caulking creates a black sludge that stains. It's OK if it's used on a Swim Platform or rear cockpit where you can easily wash away the sludge, but if you put it up on say, a flybridge or stairs, then it may be a problem trying to wash away the residue without staining all below.
Wayne
Larson 310
I have Flexiteek on our swim platform. We hate it. Sure, it hides footprints and other crud. And when wet it does have better traction that a lot of so-called "non-skid" markings on gelcoat. But the single biggest downside is it get VERY, VERY HOT in direct sun. It's too hot to even walk on with bare feet (and I've got tough feet). And it does tend to snag or otherwise kind of scrape any fancier fabrics on bathing suits.
As for using teak instead, get real. Where most of this stuff gets installed has no adequate way to attach actual teak inserts. That and there's no way I'd put up with having to maintain teak. If I want that I'd get a blow boat.
