Florida Keys Bugs
I also posted this in the south Florida forum. My son and I are going on a week long sailing trip with the Boy Scouts out of their sea base camp located on Lower Matecumbe Key, Fl. We will be sailing to Key West and back anchoring out at night. The boat is a large schooner and is not air conditioned. I am thinking sleeping on deck will be the most comfortable from a temperature perspective, however I am worried about the bugs. Could any of you south Floridians shed some light on the bug situation?
thanks
eric
Be careful. They've been known to carry off small children...
Just posted a reply for you over the SFBC forum and saw this here, too...
The greatest assortment of bug sprays, perhaps every one in the world, is available at the Flamingo FL outpost at the bottom of the state, in the Everglades. There is supermarket style shelving six feet high and 30 feet long filled on both sides with "preparations".
If that doesn't give you an idea then consider the fact that the mosquito is considered the state bird.
I would agree that sleeping on deck, if it is not stormy will be a good way to pass the night. There will be perhaps less noise on deck--less water noise and fewer elephants running back and forth on the deck above. I would start with "Skin so soft" as a basis, then apply a good DEET bug spray, such as Backwoods Off. You might also consider "investing" no see-em netting. I have some i got military surpluss. Also fine mesh bridal vail material works--and is cheap. You can make a covering of the no see-em net--and use a light sheet--plus I would want an air matress, if they don't already have sleeping pads. You would best use one of the self inflating 2" pads, such as Thermorest, not a 16" thick air matresss. Even one of the plastic air matresses is fine--the multiple tubes. One of my favorits, I have had for over 30 years, is a bicycle air matress--nylon cover, and multiple tubes, each inserted into its sheath. Only about 1 1/2" thick, but very comfortable--and good for back packing because of the light weight.
Eric
If you just insist you must do this, you are starting right by asking for bug help. Not too much from mosquitos in the keys but if you are anywhere around mangroves you will have the tiny black fly called no-seeiums. They love to get on your scalp and bite. As Bob said, skin-so-soft really works. But the best way is to keep away from them. Try to anchor upwind of any mangroves or islands. If you can, anchor 100 yards or more from the shore. They don't fly more than 100 ft usually but the wind will carry them. It's no fun to have to move during the night when you are anchored up to get away from them. They don't come as one or two, they come in clouds. Remember to post your night lights. Have a good trip.
the crew of the boat likly can provide the best information if they have done this before. A larger boat is unlikely to anchor close in to shore and the bugs. More comfort would be found out a bit where a breeze would be expected and bugs fewer. Nobody in their right mind would anchor near the southern everglades in summer or rather after they experienced the mosquitoes for one night they would be unlikely to be in their right mind.
I just returned from key west and found it no more buggy than any other area. Bring some benedryl along for the no seeum bites and long pants or at least socks for walks ashore to stop the ankle biters.
Thanks everyone for your replies. Looks like I will be going out tonight and purchasing a few more items for this trip.
thanks
eric
100% deet can be found at a number of sporting good stores, Academy, here in Okie land is one. I think the current view on deet is it isn't a cause of cancer, but who knows what will be said tomorrow. I’ve seen bugs in Florida the size of small rodents.
I have learned that deet and most plastic and vinyl things don't react well together, (at any level of concentration), and it can damage the plastic. I stuck like Velcro to the side of my truck door the other evening, and it marked the plastic after I pulled away.
We try to spend the nights as far from shore as possible (safely) and have had no problems with no-see ums when anchored that way. When close to shore, we put the curtains and screens up, and turn on the fans.
Wishing you a fun trip !!
Stan:
Thanks for the info. I knew about deet and plastics. I once had a small bottle of deet based insect repellent and left it in my fishing bag. The next time I went out to go fishing there was a hole melted into the side of the bag where the repellent bottle was sitting.
I plan on hitting one of the local sporting goods stores tonight after work to get some deet based repellent among other things. Using deet doesn't bother me as there are alot of other things that will kill me before the deet will.
thanks
eric
As an ex-Scoutmaster, I've used my share of deet based products over the years. Unfortunately, I've found that I've developed an allergy to the stuff - I get pretty bad skin rashes from using it. So, before you go all deet, you might want to give some a try prior to departure. Benedryl has worked in eliminating the rash for me. I now purchase non-deet based bug repelents. There's one I picked up at Eastern Mountain Sports that is citronella based - works pretty good. There are some other products on the market that advertise no deet - you've got to try them to determine if they work for you or not....
Good luck,
In the wetlands around Okeechobee, along the coast, in the Keys we use Skin-so-Soft by Avon. Splash a little on a wet paper towel and sponge off. You will hear them swarming around in the night but no bites.
Good Luck,
L.C.
Just a follow-up with regard to this trip. Never needed any repellant. One morning when we were anchored close to an island the wind died down and the no-seeums took over. It was around 6:30 or 7:00 so I just got up and started my day and didn't bother with repellent. We ended up leaving shortly there after anyway. Other than that no issues with bugs.
By the way, awesome trip. Any scouters out there look up Florida Sea Base for a trip. Way better than I expected.
Eric
eric
